OECD Over Engineered Chicken Door
A cage door to let slip the chickens of war when the sun goes down.
0 followers
Started simple but have moved on to over engineered - for fun
Automatic sundown, sunset and night detecting sliding chicken enclosure door controlled by arduino.
Using 2 limit switches and an Light dependent resistor.
To let slip the chickens of war when the sun goes down a bit, then close again at night.
The chicken door started because we let our backyard chickens out at about 6pm, then close the door again when they have re-entered the enclosure to sleep.
They have a limited time outside because they tend to  wreck the garden and plants if they are left out all day.
Unfortunately we forget sometimes:
Forgotten ActionEffectResult
let them out - sunsetbad for chickensChickens hungry and cranky
close the door - nightbad for gardenChickens attack at dawn
So a light based chicken door was called for
Start with a sliding door run on a ball chain drive - motor driven by arduino with motor shield
- run on solar power.
At present using a LDR for the light sensing but will move to solar cell voltage
Later  additions would include a chicken feed holder door as well.
To lock up the chicken feed from the attack of the rats. But that is a later project.
door test.wmv
Video of door test
x-ms-wmv - 1.85 MB - 07/27/2017 at 08:51
Download
sketch_working_door.ino
Start of the door coding
ino - 7.55 kB - 07/27/2017 at 08:12
Download
  • Door tests ok with dusk and night
    Leibhold07/27/2017 at 08:54 0 comments
    The LDR is working ok for dusk night and day detection but needs to be averaged out more to prevent false dusk detection - with a cloud or something
    While the door works, it is a bit ... yeah.
View project log
