The 'Configum-2' FPGA module
The most integrated FPGA module as of 2017
This tiny 30x30mm module fits into standard PLCC84 socket and offers:<br>Artix-7 FPGA, 64Mb configuration flash, 1Gb DDR3, 16Gb eMMC, ESP32 dual-core controller, 64Mb external firmware flash, USB host, 4-channel motor controller, 24MHz oscillator, dual power supply that provides 1.8V and 3.3V to external circuit with over 3A budget, on-board debug LEDs, differential ADC, up to 61 external I/O ports.<br>FPGA and ESP32 share most of the external pins and can work in parallel.<br>Configum-2 is ideal for ultra-dense high-end boards for robotics, AI, industrial, wearables, etc.<br>Can&apos;t beat that! B-)<br><br>The project is available to the Circuit Maker community: <a target="_blank" rel="noopener noreferrer" href="https://workspace.circuitmaker.com/Projects/Details/Konstantin-Dimitrov-6/Configum-2-FPGA-Controller-Module">https://workspace.circuitmaker.com/Projects/Details/Konstantin-Dimitrov-6/Configum-2-FPGA-Controller-Module</a>
Configum-2.pdf
Schematic
Adobe Portable Document Format - 709.12 kB - 10/14/2020 at 08:30
Preview
ostropest wrote 12/17/2019 at 22:25 point
great, when I can run linux on this device and working offgrid for 12h?
EngineerAllen wrote 07/24/2017 at 18:37 point
its like a SoC
Kn/vD wrote 07/24/2017 at 19:08 point
Well, yes. That's what it is - a hybrid SoC
EngineerAllen wrote 07/25/2017 at 04:12 point
maybe cheaper in low volume
Dylan Brophy wrote 07/25/2017 at 04:02 point
But better (I think)
