Summer comes with increasing heat, as a diligent DIY fan how could I do nothing but just eat ice cream?I need to design a small present to you and myself, something cute and interesting, how about a small penguin? Guess that it stands in front of you and winks, sayin‘ May I help you?
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image003.png)
Besides its look, one of important features is the special penguin step, which makes the robot lovely. Therefore, I stress the wobbly step a lot. Fortunately, I found here comes with chirps when the robot shakes its head, the friction between gear and wooden structure during the working progress. The natural penguin-style sound helps me a lot.
Come to check my work!
I used to choose normal Arduino UNO as the main board in the beginning. However, Arduino UNO does not have in-built motor drive chip and it is too large, I have to buy an extra motor drive expansion board, which is expensive and hard to connect. Luckily, I found Romeo BLE mini board is so appropriate for my project. The mini board is fully compatible with Aruino UNO and with in-built motor drive chip, small and easy to install. In the result, I chose Romeo BLE mini board as the core board without any hesitation.
Hardware in need:
1. Romeo BLE mini - Small Arduino Robot Control Board with Bluetooth 4.0
(The board compatible with ArduinoUNO and integrats 2 way DC motor driver, independent power supply of Bluetooth and gear, becoming more powerful)
2. TowerPro SG90C 360 Degree Micro Servo (1.6Kg)
3. TT Motor with Encoder (6V 160RPM 120:1)
4. Wooden infrastructure component
5. Colorful connections printed by overlord 3D printer ×2
*Click here to download document for 3D printing.
*Click here to download 3D design sketch.
*Click here to download CAD document for laser cutting.
The penguin robot can promoted to test temperature with DS18B20 Temperature Sensor and LCD display screen.
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image004.png)
Working Process:
1. Take wooden infrastructure component.
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image007.gif)
2. Build motor parts.
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image008.png)
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image011.jpg)
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image012.png)
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image016.png)
3. Make direction control parts.
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image020.png)
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image023.jpg)
4. Complete machine assembly.
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image025.jpg)
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image026.png)
5. Complete robot penguin look.
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image031.png)
6. Connect electric circuit.
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image033.png)
![](http://image.dfrobot.com/image//Blog/Arduino%20Robot/image035.png)
The code in need is as below:
* @file PenguinROBOT.ino
* @copyright [DFRobot]([url=http://www.dfrobot.com]http://www.dfrobot.com[/url]), 2017
* @author [sc.mingyang]
* @version V1.0
* @date 2017-07-7
#include
Servo myservo;
void setup() {
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
myservo.attach(2);
digitalWrite(3,LOW);
digitalWrite(5,HIGH);
void loop() {
for(int x=1; x<10; x++) {
myservo.write(75); //[/b][b]experimental result[/b][b]
delay(500);
myservo.write(135);
delay(500);
myservo.write(115);
delay(500);
myservo.write(115);
delay(500);
myservo.write(75); //Turn right
delay(3000);
myservo.write(135);//Turn left
delay(3000);
myservo.write(105); // Go straight
delay(8000);
