Amherst Makerspace Maker Station
A system to manage makerspace members access to equipment
0 followers
The goal of this project is to control access to the machinery at the Amherst Makerspace. The goal is to prevent untrained members from damaging themselves and the machines. The system will utilize a central server, and many distributed authentication/activation units.
The Amherst Makerspace is a joint project between the Amherst Middle School and the Amherst Rec. Department. We are utilizing a wing of the school to provide 10,000 sq ft of Makerspace, Art, and computer engineering during the school day, and the same space to the community at night. The goal is to improve the kids space for the day and the adults space at night.
One challenge is that we operate without a "life guard", you are trained to use the equipment, and are expected to operate it safely. As our membership grows we need to enforce the training first priority with a little technology. To this end we are adding card readers to each machine that prevent people from activating it if they have not been authorized. Every member has an RFID card for door access, so the same card will be used for machine access.
MakerStation_5.zip
Board Fabrication ZIP file
x-zip-compressed - 252.99 kB - 01/17/2024 at 04:11
Download
MakerStation_5.fzz
Maker Station Fritzing file
fzz - 512.57 kB - 01/17/2024 at 04:10
Download
Enclosure.scad
Enclosure OpenSCAD file.
scad - 10.98 kB - 01/17/2024 at 04:07
Download
  • 1 × EPS 32 or similar in the Feather format https://www.sparkfun.com/products/15663 or Similar
  • 1 × RFID Reader with I2C. QWIIC wires if supported by the Reader and the ESP32. https://www.sparkfun.com/products/15191 You will also need an antenna that matches the card type you are using.
  • 1 × Custom PCB for easy wiring and mounting
  • 1 × 2 Gang Electric Enclosure
  • 4 × LEDS, Blue, Red. Gree, and Yellow
View all 8 components
  • 5 lb bag with 10lbs of stuff in it.
    Marcel Chabot01/17/2024 at 03:57 0 comments
    Originally, we were planning on ordering enclosures and modifying them for the card readers and LEDs. However, I was walking through my local home improvement shop and noticed a 2 gang electrical box. Thinking to myself I bet I could make everything fit in that box.
    I grabbed one, brought it home and with the help of the 3D files available on the McMaster Carr web page I was able to CAD up a box:
    Yes, I use OpenSCAD. I'm a Sofware developer by day, and the tool works with the skills I already have. If you are keeping score, I use both OpenSCAD and Fritzing.
    I was able to model everything inside the box with enough space to spare for wires and power. This should work, be off the shelf, available to anyone, and be cheap!
  • Getting Board with Problems
    Marcel Chabot01/17/2024 at 03:46 0 comments
    I have a control board format selected, life is looking good. In order to keep things simple we need a board to hold make wiring easy. We need to support a few functions:
    1. Easy mounting of the ESP 32 board.
    2. Level Shifters so that the 3.3v ESP 32 can work with 5.0v logic devices.
    3. An input button that can be pull-up or pull-down.
    4. Easy access to a relay output, a card detection method, Reset button, and LED status indicators.
    We wanted minimal population effort. The board is designed to take a common 4 channel bi-directional level shifter board and the rest of JST connectors or direct wire holes for the relays and buttons.
    I know many people hate Fritzing, and I see all their issues. I learned it a long time ago, and it helps me go from breadboard to circuit board. I'm working on learning some of the alternatives out there to do more advanced work.
    I know!
    It is ugly. it is inefficient. The routing is ham fisted at best. But it is my ugly baby and I'm proud of it anyway!
    Yes, and you are reading that correctly, version 0.5. It took me 5 tries to make this monstrosity. I learned a lot along the way.
    Version 0.1 attached to a Raspberry Pi, which is a hardware system we abandoned.
    Version 0.2 should have been tested on a breadboard first, I forgot that some pins were input only, and used them for the LED outputs. That is why some of the LED lines run clear across to the far side of the board, not all the I/O pins are input and output and I had to do some odd routing to compensate.
    Version 0.3 Worked better, but we found that for the confirmation button we needed pull-up or pull-down capabilities, so we added the pads so we could configure it at implementation.
    Version 0.4 The board was too cramped. We didn't fabricate this one, it just didn't fit right.
    Version 0.5 The board was sized a bit better and we added a breakout for the Reset pin on the board.
  • Float like a feather and string like a USB.
    Marcel Chabot01/17/2024 at 03:29 0 comments
    The ESP 32 devices come in every shape and size imaginable! If we are going to have any hope of a future capable design we need some kind of standard to work with. Both Sparkfun and Adafruit sell several flavors of device on a form factor called "Feather". We are thinking if we design around this format, then we should be able to use any device that is Feather compatible. It is as close to a standard as we can find.
    The next problem is the pin outs. I happen to have three devices that are all feather boards, all different flavors of ESP 32 and they have slightly different pinouts. Power and Ground are fine, but the I/O pins are different. In the Arduino Software we are going to have to include a way to flag which board we have and use #Defines to select it. Here are the three I have already:
    //Sparkfun ESP32 THING Plus WROOM / Adafruit HUZZAH32 ESP32 Feather
    #ifdef ESP32ThingPlusWroom
    const String Board = "ESP32ThingPlusWroom";
    const int HBPin = 13;   //Heartbeat LED OUTPUT
    const int APPPin = 12;  //Approved LED OUTPUT
    const int DNYPin = 27;  //Denied LED OUTPUT
    const int ACTPin = 33;  //Active LED OUTPUT
    const int OPTPin = 36;  //OPTO INPUT
    const int BTNPin = 39;  //BTN INPUT
    const int RLY = 19;     //Relay OUTPUT
    const int DTS = 18;     //DST OUTPUT
    const int LS = 5;       //LS OUTOUT
    #endif
    //Sparkfun ESP32-s2 THING Plus WROOM
    #ifdef ESP32S2ThingPlusWROOM
    const String Board = "ESP32S2ThingPlusWROOM";
    const int DNYPin = 11;  //Denied LED OUTPUT
    const int ACTPin = 10;  //Active LED OUTPUT
    const int OPTPin = 7;   //OPTO INPUT
    const int BTNPin = 9;   //BTN INPUT
    const int RLY = 37;     //Relay OUTPUT
    const int DTS = 35;     //DST OUTPUT
    const int LS = 36;      //LS OUTOUT
    #endif
    //Adafruit ESP32-S2 Feather
    #ifdef ESP32S2Feather
    const String Board = "ESP32S2Feather";
    #endif
  • The big BOM
    Marcel Chabot01/17/2024 at 03:22 0 comments
    The initial project was designed around a Raspberry Pi 2, and later the 3. This was during the time that Arduino didn't have a Wi-Fi option, a time before the ESP series of device changed the face of the IOT world. We also anticipated the need for a user interface, however we never had need for it, and decided to remove the requirement. The also the price, the PI, the wiring, the enclosures, the power requirements, they all resulted in a Bill of Materials (BOM) that was high, and with the dirty power in the building we had SD cards burning out and locking us out of the machines.
    We needed a simpler system. Fewer bells that never rung. So, a redesign around the ESP 32 board should give us what we need, a simpler system, and a lower cost per system.
    Back to the drawing board.
  • Drastic times call for Drastic Redesigns
    Marcel Chabot01/17/2024 at 03:17 0 comments
    This project has gone stagnant, and it is due for some significant updates. Technology has changed, the Makerspace needs have changed, and the system has to change to match. I'm going to create a series of Project Log entries chronicling the process of the redesign. This is all done retrospectively, so I may miss one or more of my numerous stumbling blocks on the way, but I'll do my best to document them all.
  • Maker Over Ethernet
    Marcel Chabot07/29/2017 at 22:42 1 comment
    With about 20 machines needed network, power, and the ability to activate the dust collection, air filter or other support systems we need a simple way to wire that all across the large space. Power over Ethernet is a thing, but it is costly and doesn't have the system activation detect capabilities we want. So we have designed Maker Over Ethernet.
    It is a simple breakout board that takes network, power, and activation detection and passes it over a standard CAT6 cable. Network only requires 4 of the 8 wires, leaving two pairs for power and activation detection.
    MakerOE Board from OSHPark
    We also used some RJ-45 connectors from SparkFun https://www.sparkfun.com/products/643
    and some JST connectors: https://www.sparkfun.com/products/9914
View all 6 project logs
