Hackaday.io Hackaday.io
Sign up Log in
Slack-Connected Party Parrot
Send or react to a Slack message with any party parrot, and the real one will come to life too
claireClaire
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
113
0
2
4
Team (1)
  • claireClaire
Join this project's team
completed project
hardware
arduino Particle PHOTON slack
Related lists
my liked projects
projects that I like and want to browse again
This project was created on 09/05/2017 and last updated 9 years ago.
Description
This internet-connected party parrot will light up and begin moving anytime you use the party parrot gif/emoji on an authorized Slack channel. (If you aren&apos;t familiar with the party parrot, see this article: <a target="_blank" rel="noopener noreferrer" href="http://mashable.com/2017/07/13/cult-of-the-party-parrot-slack-reddit-meme/#_3khvE5LNSqt.)">http://mashable.com/2017/07/13/cult-of-the-party-parrot-slack-reddit-meme/#_3khvE5LNSqt.)</a><br><br>The parrot is powered by a gear motor, an Arduino Uno, and a Particle Photon. A Slack app is installed and authorized on the desired Slack team and then subscribes to the message and reaction added events. The Slack app calls a webhook on a Node JS app anytime an event is fired; the webhook scans the input text for any sign of a parrot and calls a Particle function hook if detected. The Particle function then pulls an input pin high on the Arduino for five seconds, which triggers the parrot&apos;s movement sequence.
Details
Components
  • 1 × Arduino Uno
  • 1 × Particle Photon
  • 1 × RGB LED
  • 1 × Hobby Gear Motor
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
In this tutorial, we will check how to apply the SHA1 algorithm to a message using the Arduino core on the ESP8266.
Project Owner Contributor
ESP8266 Arduino Tutorial: Using the SHA1 algorithm
muzimuzi
Add spoken feedback to any Arduino project by sending text and sensor values to a TinyTTS module over UART — no cloud, no audio files.
Offline Talking Sensor with Arduino and TinyTTS
paulPaul
A binary message beeper for the Arduino demonstrating the Arecibo message
Arecibo message from an Arduino
matt-hughesMatt Hughes
Supplyframe DesignLab: 2023 Hackada…
I2S output FM Tuner using RDA7088 with RDS display using ESP-01 and OLED
I2S output FM Tuner with RDS
mit41301mit41301
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Slack-Connected Party Parrot", please tell us the reason.
Send message
Remove Member
