IBM Watson IoT Cloud Authentication w STM32 Nucleo
Successfully authenticate IBM Watson IoT Cloud with the STMicro Nucleo with MEMS gyro, accelerometer, magnetometer, temp, pressure sensors.
IBM Watson IoT Cloud Authentication with STMicroelectronics Nucleo MCU and MEMS Gyroscope, Accelerometer, Magnetometer, Temperature and Humidity Sensors
Successfully authenticate IBM Watson IoT Cloud with the ST Micro Nucleo with MEMS gyro, accelerometer, magnetometer, temperature, pressure and humidity sensors
You will need to follow all of these steps to flash your ST Micro Nucleo, create an IBM Bluemix application instance, and finally connect it all via MQTT to the IBM Watson IoT Cloud.
Follow URL link to LinkedIn Article for instructions.
STM32_Flash_Loader-2.8.0.zip
STM32_Flash_Loader-2.8.0.exe may be optional
Zip Archive - 33.38 MB - 09/05/2017 at 04:02
Download
STM32_ST-Link_Utility-4.0.0.zip
STM32_ST-Link_Utility-4.0.0.exe required
Zip Archive - 22.72 MB - 09/05/2017 at 04:01
Download
MQTT_IBM_STM32F401RE_Nucleo-IKS01A1.bin
FP-CLD-WATSON1 firmware for STMicroelectronics Nucleo Board required
octet-stream - 108.49 kB - 09/05/2017 at 03:53
Download
  • 1 × STMicroelectronics Nucleo STM32F401 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers.
  • 1 × STMicroelectronics X-Nucleo-IKS01A1 MEMS Inertial and Environmental Expansion Board.
  • 1 × STMicroelectronics X-Nucleo-IDW01M1 Wifi Expansion Board.
  • 1 × STM32_ST-Link_Utility-4.0.0.exe STMicroelectronics Firmware Flash Utility required.
  • 1 × STM32_Flash_Loader-2.8.0.exe STMicroelectronics Firmware Flash Utility may be needed as well.
View all 7 components
View all 5 instructions
