Sensing relays
A project log for YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
Yann Guidon / YGDESYann Guidon / YGDES 10/15/2019 at 00:282 Comments
The RES15 relay is nice but requires way too much current to operate, in particular in some circuits where low current is necessary : the DRAM sense circuit as well as the instruction sense circuit, because 16 bits multiply the coil current, that reaches a value that can't be reliable...
Another type of relay is required and @Artem Kashkanov  suggested the RES55 : a reed-type relay with the typical fast operation and low operating current, though at a higher voltage.
I couldn't find a suitable lot of this reference on eBay but found 2 other things :
I just tested the 1A12 and I am impressed : the contact closes at about 5V (varies with the piece) and opens at about 3V, with a current under 2mA. With such a hysteresis and low power, it even becomes interesting to use them for the register set...
I still have to receive the RES-64A, which would look way better, and I'll have to compare it to the modern miniature version. However there is now a good solution to the problem I had before : I can switch 16 bits on, and draw at most 2×16=32mA, which will not strain the address decoder's contacts much.
Oh and I still have to design that automated relay tester...
Artem Kashkanov wrote 10/15/2019 at 11:18 point
And reed relays are pretty faster than usual one,. so It can be very helpful for DRAM refresh logic.
Yann Guidon / YGDES wrote 10/15/2019 at 11:33 point
yes however they can handle/switch less current and most often are SPST. So I use them as "amplifiers" for now.
If I start to want to replace all the RES15 I'll need DPDT reed relays and they use a higher voltage so it would also change all the power supplies and topologies...
DRAM refresh logic will be quite simple, I think. With a sensitive current sensor, the capacitor can retain data longer and refresh slower, reducing the wear of all the contacts.
