Pong Game
Handmade gaming console
Pong is a two-dimensional sports game that simulates table tennis. The player controls an in-game paddle by moving it vertically across the left side of the screen, and can compete against another player controlling a second paddle on the opposing side. Players use the paddles to hit a ball back and forth. The aim is for each player to score some points before the opponent; points are earned when one fails to return the ball to the other. Our idea is to realize the basic implementation of the game by using a suitable microcontroller interfaced with an LED Dot Matrix display and buttons for each of the two players. Both the players will have two buttons each to control the movement of their respective paddles (Up and Down). The paddles however are restricted to move horizontally. While there can be multiple implementations of this game, we wish to stop the game when any of the players reach a certain score. The score increases by one if the opponent misses the ball.
This project was implemented as a partial fulfillment of the course Embedded Systems Design wherein we developed a 2 player Pong game similar to the classic Atari pong game.
The game is implemented on Atmel Atmega16 Development Board.
  •  Using a 8x8  monochrome Red LED matrix (MAX 7219).
  • Simple pushbuttons for user control.
  • Scoreboard using 7-segment displays.
  • The buzzer was also programmed for producing sound.
  • The game also has a reset button.
The buzzer produces annoying sound using PWM whenever someone scores a point. It also plays a melody at the start of the game.
The game can be powered either by a battery or by connecting to a PC through a USB cable.
The file 'final.c' is the final game implementation
Also added Proteus ISIS file 'avr_matrix.DSN' for simulation.
doc2466.pdf
Documentation of ATMega16 L
Adobe Portable Document Format - 7.14 MB - 11/29/2017 at 14:35
Preview
Commands for compilation and burning the HEX file.
JPEG Image - 64.17 kB - 11/29/2017 at 14:35
Preview
pong_final.hex
Hex file for running proteus simulation.
hex - 21.08 kB - 11/29/2017 at 14:25
Download
Schematic
JPEG Image - 252.57 kB - 11/29/2017 at 14:22
Preview
avr_matrix.DSN
Proteus Design File
dsn - 116.70 kB - 11/29/2017 at 14:22
Download
View all 8 files
  • 1 × ATMega16 L Development Board
  • 1 × USB ASP Programmer
  • 1 × LED Dot Matrix MAX 7219
  • 1 × Breadboard Electronic Components / Misc. Electronic Components
  • 1 × 9V Power Supply
View all 8 components
  • Current Progress
    Shikhar Shiromani11/29/2017 at 09:32 0 comments
    The entire game has been implemented and few functionalities have been added like melody at the start of the game.
  • Progress till 18-11-2017
    Shikhar Shiromani11/19/2017 at 20:16 0 comments
    Update:
    • Tested the LED Dot Matrix Display.
    • Test AVRDude to burn sample hex files.
    • Installed drivers for USB ASP Programmer.
    • Tested the user inputs.
    • Designed a layout for the connections.
    • Partially designed the simulation in Proteus.
    To Implement :
    • Implement the game code.
    • Final launch, run and improvisations.
View all 2 project logs
View all instructions
