So after several attempts, I have figured out how to make a TOR NETWORK ROUTER using a Raspberry PI. I have attached Instructions on PDF file, which includes what you need. and 2 application modules.
Files
Topic 1.1 How to make a tor network router PDF.pdf
This is a FULL set of instructions, which needs be done exactly as it is said. Also tells you what you need for the project.
Adobe Portable Document Format -
283.16 kB -
11/12/2017 at 16:06
raspberrypi systemd[1]: Failed to start LSB: DHCP server.
On raspberry pi 3 B.
