Topic 1.1 How to make a tor network router PDF.pdfThis is a FULL set of instructions, which needs be done exactly as it is said. Also tells you what you need for the project.Adobe Portable Document Format - 283.16 kB - 11/12/2017 at 16:06 |
pifi.shhis script turns your Pi into a WiFi access pointBourne Shell Script - 6.27 kB - 11/12/2017 at 16:05 |
tor.shThis script routes your WiFi access point through the Tor network. Run pifi.sh BEFORE this script.Bourne Shell Script - 3.45 kB - 11/12/2017 at 16:04 |
