Light and Dark Mode...
A project log for Electronic Dice
A set of smart dice, the same size as traditional ones, full of LEDs and Bluetooth-enabled.
Jean SimonetJean Simonet 09/30/2019 at 14:415 Comments
Hey there!
A quick update with pictures of the updated D20. I am testing different combinations of materials and silkscreen colors for the dice.
The challenge here is to find a combination that diffuses the light nicely, without blocking most of it out and still looking interesting when off.
---------- more ----------
This is what the black and white die look like in bright sunlight. There is only so much the LEDs can do at this point, but, hey, that's why it's important for the dice to still be readable when off.
dan wrote 10/11/2019 at 13:15 point
I'm really looking forward to seeing these come to market! Will you have completely opaque ones where you can't see the inside components? Any way to 'subscribe' to know when they might be available from you (or if you're willing to sell a prototype?).
daid303 wrote 10/01/2019 at 14:31 point
$25/die sounds pretty cheap. Then again, shipping to Europe will most likely add a chunk for me.
daid303 wrote 10/01/2019 at 11:06 point
I was wondering, are you planning to bring these to market? I can understand that they won't be cheap, as manufacturing will be a challenge.
Jean Simonet wrote 10/01/2019 at 13:22 point
I am, and am trying to figure out manufacturing actually. My don't-quote-me estimate right now is that I should be able to sell them for $25/die or $150/$170 for a full polyhedral set and charging case.
daid303 wrote 10/02/2019 at 08:43 point
$25 is very reasonable, even cheap I think. Then again, I most likely need to get them for all my friends as well...
