IMG_0018.JPGShure Brothers Fat Boy is from ca 1940JPEG Image - 1.73 MB - 12/02/2017 at 14:32 |
IMG_0019.JPGclose examination insideJPEG Image - 1.83 MB - 12/02/2017 at 14:32 |
JPEG Image - 2.01 MB - 12/02/2017 at 14:32 |
IMG_0023.JPGthe cutest repair of the deteriorating foam cushionsJPEG Image - 1.36 MB - 12/02/2017 at 14:32 |
IMG_0020.JPGPulling the transformer out of its socket. The connector is reversed and broken, and needs replacing. The solder at the connector need de-soldering and the cable can be pullet out. Cleaning and repair can begin.JPEG Image - 1.98 MB - 12/02/2017 at 14:32 |
IMG_0022.JPGThe connector was apparently once replaced and is now also broken. Strangely, it has a female connector and the brass screw holding it in place is all chewed up. But I still managed to open it and lift the broken connector out.JPEG Image - 1.42 MB - 12/02/2017 at 14:32 |
