Hackaday.io Hackaday.io
Sign up Log in
hackOx
HackOx is a web-based pentesting framework which implements a fully customizable user interface for nearly any tool out there.
deantoniousdeantonious
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.7k views
0 comments
307 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
2.7k
0
307
21
Team (1)
  • deantoniousdeantonious
Join this project's team
  • Website
Software
ongoing project
hacking
This project was created on 12/02/2017 and last updated 8 years ago.
Description
HackOx is a web-based pentesting framework which implements a fully customizable user interface for nearly any tool out there. It can be operated two different modes: portable mode, in which you connect directly to the device and remote mode, that will connect the device on where it's installed to your own control for remote controlling (supports multiple devices). The interface can be customized by adding modules, which extend the core functions and implements tools running on linux and apps, which are scripts that can be executed with/without arguments and will generate a plain text output.
Project Logs
Collapse
  • Official discord server
    deantonious • 02/03/2018 at 17:57 • 0 comments
    Hey everyone! A few weeks ago I created the hackOx Discord server so everyone can join! There you'll find announcements, changelogs, community development channels and the CTF to join the Beta: https://discord.gg/xeNZust
  • HackOx Core 100% working
    deantonious • 01/03/2018 at 16:03 • 0 comments
    Good news! The #hackox Core is 100% working! Now it's time to make some modules, apps, documents and make sure everything works ok!
    https://twitter.com/hackOx_dev/status/948577073781772289
    We're planning on opening the code to a small group of betatestesters (maybe chosen with a CTF):
    https://twitter.com/hackOx_dev/status/948549859732226050
  • Release date delayed
    deantonious • 01/01/2018 at 19:18 • 0 comments
    We're sorry but as you all may have noticed we couldn't release hackOx on the planned date. We thought everything would be ready (core software, modules, apps, documentation, etc) but since we're all studying and/or working we just didn't have enough time. We're making a poll on twitter to decide whether if we should release everything now (unstable, without docs, etc) or when it's stable:
    https://twitter.com/hackOx_dev/status/947905573818982401
    Thanks to everyone for supporting the project.
  • First release date
    deantonious • 12/02/2017 at 14:17 • 1 comment
    It's been a while since I started developing this project and after lots of hardworking, I've reached the 80% of what I planned for the first release. This release will take place during the 34C3 in Germany (hope everything works for then). It will be a "Install at your own risk" release but it will be enough to test the power of this tool. It can be installed on any Pi device and has endless posibilites!
    We'll be at the Schinfo Assembly at the CCC and will bring some project stickers :D
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
The project deals with the face recognition for pause/play option and fist detection for volume control.
Project Owner Contributor
Gesture and Face Recognition
sharmaayush1995sharma.ayush1995
The 2017 Hackaday Prize
MFRC522 RFID on ESP8266 featuring WebSocket, JSON, NTP Client, Javascript , SPIFFS
ESP RFID
omersiaromersiar
The 2016 Hackaday Prize
An internet backed by torrents and the blockchain
A Truly Distributed Web
william-blankenshipWilliam Blankenship
A proper implementation of a ESP32 CAM webserver; based on the Espressif example, but extended for real-world use
$7 ESP32 CAM example expanded
owenOwen
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "hackOx", please tell us the reason.
Send message
Remove Member
