TODO
11/02/2020 at 07:10 • 0 commentsAll the lion kingdom's LED displays were made before 3D printing arrived, even the outdoor thermometer. 3D printed white PLA actually could make a good diffuser. The lighting isn't as even as some clocks, but much better than heroineclock II. This guy threw a lot more money at store bought components instead of making everything from scratch. There are individually addressible LED strips which can show different colors, a much more powerful computer which gets time from wifi, a much heavier enclosure which requires a lot more hardware to mount on a wall. His other projects are manely toys, but there are a few good ideas. Lions actually want the time to drift fast instead of precisely track wifi. It could benefit from 3D printed diffusers, but not replacement of the LEDs.
New remote arrangement
09/19/2020 at 23:34 • 0 commentsWith the addition of seconds & the remote also supporting the robotic air vent, it was time for some adjustments.
Thermometer 3
08/14/2020 at 05:53 • 0 comments4 reconstituted autopilot boards from 10 years ago were reprogrammed & reworked for their new life as a sensor network.
1 transmitter board transmits the temperature from outside.
1 transmitter board transmits the temperature from inside.
1 reciever board sends the temperatures to the router.
1 receiver board sends the outside temperature to a new LED panel.
The outdoor thermometer runs at 32.768khz. The PIC18F14K50 was found to use 150uA in idle & up to 30mA when transmitting. It needs to transmit for a long time to overcome interference. The easiest error correction is to transmit more data. The PIC uses its maximum baud rate of 8192 baud. The internet said the sleep current is lower when using the watchdog timer instead of idle mode, but this was found to not be true. The watchdog timer can go to 120 seconds, but it would have to take all its ADC readings at the moment of transmitting instead of averaging them over 120 seconds.
The thermometers transmit a 16 byte key to identify themselves, followed by the temperature repeated 4 times. The key & temperature are also repeated 4 times.
The existing thermometer board got a retrofit to transmit temperature to the router. After 16 years of just showing the temperature, giant thermometers could finally record the temperature.
After much debate, the outdoor thermometer got a new voltage divider to measure battery voltage. It doesn't need to measure battery voltage over its many years of temperature measurements. It only needs the battery voltage to test the solar panels in its 1st day. The problem is the alternative is to go outside with a voltmeter several times.
Its idle current increased to 200uA & lions rediscovered the ground for the voltage divider can't be a GPIO or it'll sink the high voltage from the battery. When the power usage is this low, the high voltage from the battery raises Vdd.
As bad as the compromises seem, the power usage is actually tiny compared to a modern standards based solution. The modern solutions use an ESP32 & wifi. They have to stay on for a long time to negotiate a wifi connection, which tends to erase any gain from their nano amp sleep current.
It was frustrating to discover despite being only a temperature sensor in a very suboptimal location, the enclosure still needed to be a proper weather station enclosure to get good results. Much cardboard prototyping yielded something like a bird house with a way to access the innards. Now the lion kingdom knows why it needed to keep around a speaker stand for 20 years. The mane problem is keeping the wind from giving the neighbors a free $90 thermometer. It's cost as much just to get temperature as a full chinese weather station.
Thermometer with a smile, you might say.
Junk NiMH battery from an ECX Ruckus rated for 7.2V.
Waterproofing the battery.
Trying to protect the electronicals from condensation.
Failed attempt to isolate the thermistor from conducted heat.
The enclosure size was dictated by the solar panels.
The electronicals were buttoned up & it was put outside. The thermister was 5 deg higher than wunderground at night & 15 deg high by day . The fluke was 20 deg higher than wunderground at night & bang on by day, despite being in the exact same place inside the enclosure. Location of the thermistor inside the enclosure affected temperature. The area without circulation was much hotter than the area with circulation. When indoors, the thermistor was bang on.
The thermistor:
https://www.digikey.com/product-detail/en/littelfuse-inc/DC103G9G/615-1054-ND/1783432
A full day of measurements revealed it suffered from heat conduction. A new assembly made of magnet wire & balsa would conduct less heat from the coroplastic. This was still higher than wunderground by 1 - 3 degrees but much closer. If it was exactly the same as the wunderground stations, it would be a waste of time.
Discovered the best way to check the thermistor is putting the fluke in the HVAC inlet. That shows the thermistor with its magnet wire suspension is within 1 degree of the true outdoor temperature & the outdoor temperature really is a few degrees off of wunderground. It's been surprising how accurate these home made thermometers have been, since they're solving the Steinhart–Hart equation in fixed point math.
The key to measuring air is to overcome the self temperature of the fluke. The fluke's self temperature isn't a problem in its normal task of measuring metal because metal has a higher heat capacity, but it is a problem when measuring air because air has a low heat capacity.
The 1st day of solar charging revealed acceptable results with the radio transmitting every 30 seconds & the ADC sampling every second. It managed to get a net charge without direct sunlight. Only a brief period with direct sunlight got it to 7.2V. It finished the day with higher voltage than yesterday.
It'll never fully charge the battery, but the idea is to have enough reserve capacity to keep the battery from getting hot. Sizing the battery to optimize the used capacity is a long term project.
It uses 2x 1W 8.2V panels in series.
https://www.digikey.com/product-detail/en/seeed-technology-co-ltd/313070005/1597-1418-ND/5488048
Getting the outdoor panel up to a readable state got the entire 4 radio mesh running. It was the lion kingdom's 1st temperature display which relied on a radio instead of a thermistor directly connected to it. When it doesn't get a packet for 1 minute, it shows an invalid code rather than an obsolete temperature.
The lion den command center was complete.
The lion kingdom realized there are better diffusers than wax paper, which would look a lot better. The wax paper dates back to heroineclock 1, which tried to minimize cost. When the solar panel costs $25 & the coroplastic is $20, the diffuser isn't an obstacle anymore.
Used wrapping wire instead of ribbon cable for this one & it looked the cleanest. The $1 car USB chargers were finally used as buck converters for the input power. Those are the last of the hackable car USB chargers.
Exterior temperature plan
08/10/2020 at 04:42 • 0 commentsWith no need to spend all day commuting, there has been a growing desire to measure outdoor temperature without the grid & recording the indoor temperature. There are a lot of temperature sensors on the internet, using ESP32 & ESP8266 boards, exotic capacitors, lithium phosphate batteries, space grade solar panels, sucking megawatts of power to promote the latest wifi standards. It's all a bit overkill, but representative of a time that emphasizes very suboptimal, off the shelf parts using every multibillion dollar consortium's bloated standard.
The lion kingdom still has a lot of very optimized parts for this task from 10 years ago, when everything was purpose driven & had to be built from scratch. Lions in those days evolved the equivalent of an IOT board out of a PIC18f14k50 & SI4421. It used a milliamp at most when transmitting, & 3.3V. The power consumption was so low by today's standards, it could run on some NiMH batteries & very cheap solar panels. Lions wouldn't use Lithium batteries for this task because of the daily cycling.A small armada of these boards was built 10 years ago for transmitting heading from copters. Today, they would be prized for their remote sensing ability. They could be reworked for transmitting temperature. The home router would have a board for receiving the packets.
There isn't enough room to display the outdoor temperature on a wall, but a web page could show it. The temperature display could also receive packets & alternate between the indoor & outdoor temperatures. There's no need to measure anything but temperature in Calif*.
Wishlist
07/28/2019 at 00:31 • 0 commentsA lot hotter since the thermometer was installed. Lions have debated adding an exterior thermometer, a seconds display, & temperature logging.
The seconds display is the least likely. It would manely make it easier to wake up as close before the alarm as possible, but it would add a lot more blinking & it would be hard to see.
All enhancements to the thermometer point to a mesh network. The lion kingdom has a supply of XBees, but they use a lot of power. Temperature logging for the indoor thermometer would have unlimited power. Temperature logging outside would require solar power.
Clock documentation
04/04/2019 at 16:30 • 0 commentsA year without commuting allowed the clock interface to never be used. With the return to commuting, the lion kingdom had manely forgotten how to set the alarm. It was time to document the control. This is the last Yamaha remote the lion kingdom will ever have & it arrived 20 years ago with a stereo that's long gone. The next remote once this one is lost will be completely different.
The remanes of Heroineclock I
08/16/2018 at 03:47 • 0 commentsThermometer II was made out of the known good LEDs from Heroineclock I, which left the original faceplate & questionable LEDs ready for landfill.
It was seriously overbuilt & had a lot more features. Was surprised to discover the plastic was covered in window tint to make it darker, while also losing some brightness.
It's long journey since being painted in 2004 had come to an end. The electronic section still has hope.
Whether the original balsa faceplate could be reused is doubtful. The lion kingdom doesn't foresee any way to afford a 2nd room. It's much bulkier than its size requires.
Thermometer II completion
08/14/2018 at 08:34 • 0 commentsBe sure to label your GPIOs.
2 layers of wax paper, just like Heroineclock II were applied. The ancient LEDs were maxed out & it was still dimmer than Heroineclock II's minimum brightness. If you don't have any money, it says 81. If you have money, it says 72.
An accurate temperature reading is very very very hard because of the logarithmic resistance of the thermister combined with the logarithmic voltage from the voltage divider. Didn't realize how far off the circuit was until comparing it to the Fluke. Heroineclock 1 was calibrated only by testing ice & boiling water. Fluke measurements from ice & boiling water are way off of 32 & 212. Better results would be achieved by multiple GPIOs feeding variable current to the thermister.
The basic equation for a voltage divider gives reasonable ADC values near habitable
temperatures. A simple C program https://cdn.hackaday.io/files/284921219001728/temp_tester.c converted resistances from the data sheet to ADC values from the voltage divider. Though it had some experimental test values, the ADC values were predicted purely from the data sheet. This gave exactly the same temperatures as the Fluke, from 45F to 185F, accepting differences in thermal inertia.
To make a better video, the thermometer got a completely worthless test mode. The test mode was manely to measure its maximum current. It only used 140mAh with all the LEDs on. The PIC was clocked at only 10Mhz to reduce the power.
Thermometer 2 board
08/07/2018 at 20:39 • 0 commentsThe 1st home etched board since February rolled off the assembly line. Phones & raspberri pi's have made this fabrication extremely rare.
Those PLCC 68's are still things of beauty & joys forever. Should have used a much smaller chip, but the 68's came 10 years ago & were never used. They were meant for building heroineclock II in through hole mode, but all through hole boards of that complexity were replaced by surface mount. It's totally pointless & expensive to use them now, outside of vanity designs. It'll be in full view of the apartment until the lion kingdom dies.
It occurred to the lion kingdom to make the segments fade on, instead of smashing on like LED brakelights. It might make it easier to sleep & give it an edge over Chinese shit. It would also feel like slowing down the aging process if the numbers didn't quickly change.
Would still have to bang the LEDs on when playing sound. PWM needs to get above 200Hz. The trick is fading slow enough to not wake up the lion, to not look like an incandescent light & yet fast enough to have a useful on time. Having said that, sleeping is the only time a lion even sees the digits changing. Once you get used to it, it doesn't matter.
The https://hackaday.io/project/159267-moving-the-dvd-archive-to-an-8tb-hard-drive DVD archiving project yielded the original table for the original thermister. 20 years ago, you could obtain a bare thermister just by walking 2 miles, no shipping costs or 1 week delay. 30 years ago, someone who lived outside China even knew what a thermister was.
Useful range would be 5k - 30k. Heroineclock 1 used a carefully tuned op-amp to span the entire ADC range. Modern designs just wire the thermister in series with a resistor. A 10k gives 0.45 - 3.75 on the voltage range. A 5k resistor gives 0.83 - 4.29.
Thermometer II
07/14/2018 at 20:51 • 0 commentsThe original heroineclock had a thermometer. It could show temperature fulltime or oscillate between time & temperature. It oscillated painfully for 10 years. It could be resurrected as a fulltime thermometer, but it uses too much power. There are 33 LEDs known to be good in Heroineclock 1 & 23 spares of Heroineclock 1's vintage. A temperature display of Heroineclock 2's size needs 80 + at least 5 spares.
The framework of Heroineclock 1 could be left intact, with all the electronics replaced, LEDs rewired in series. Heroineclock 2 left behind enough transistors to do the job. Voltage regulators from Heroineclock 1 could be reused. A slightly larger display could be made with 3 LEDs per segment.
3 LEDs per segment limited the new display to 8" tall. Younger lions could make out 6" tall digits from anywhere in the apartment, so old lions might be still able to read it with a bit of effort.
The LED count limited it to 0-199 in Fahrenheit. Imperial is still the cheapest unit to display, as much as binary imperial would be even cheaper.
Lessons learned from Heroineclock II were applied to thermometer II.
Far fewer pieces of foam were cut for each digit. The foam length was limited by the amount of hot glue which would stay hot.
Apply hot glue to the paper side of the joints, not the foam side. It melts foam so nothing fits flush. Don't do what Adam Savage does.
Glue middle segments of each digit first, then work outward. This way, segments won't end up being too long for the remaneing space & the digits will naturally overrun the outlines.
Try to hold the segments vertical until the glue sets. The glue fills in the gaps from lousy cutting.
Measurements don't have to be crazy accurate, because the cutting & gluing is terrible anyway.
