J090_SC88T_test_program_2019-04-08.zip
Latest source code
Zip Archive - 128.12 kB - 05/07/2019 at 01:54
Download
J090-U9.PLD
First attempt, compiles but unproven so far.
pld - 4.07 kB - 03/17/2019 at 20:48
Download
J090-U11.PLD
pld - 2.58 kB - 03/17/2019 at 20:48
Download
J090-U11.lst
Logic compiler output.
lst - 4.36 kB - 03/17/2019 at 20:48
Download
J090-U9.lst
lst - 7.00 kB - 03/17/2019 at 20:48
Download
J090_SC88T_19040-8-E-6969_hexdump.z80
Source that assembles using the on-line assembler <a target="_blank" rel="noopener noreferrer" href="https://www.asm80.com">https://www.asm80.com</a><br>Note this just contains byte and string definitions, no mnemonics Z80, 8088 or otherwise. It was just created to check the string data.
z80 - 148.41 kB - 03/02/2019 at 21:15
Download
J090_SC88T_19040-8-E-6969.hex
Firmware that came with the board, in Intel hex file format.
x-hex - 77.03 kB - 03/02/2019 at 20:40
Download
J090_SC88T_19040-8-E-6969_hexdump.c
Binary converted to C array using the Linux command<br>xxd -i -c 16 J090_SC88T_19040-8-E-6969.bin
x-csrc - 196.11 kB - 03/02/2019 at 20:40
Download
Firmware that came with the board.<br>Resides in the last 32K of the 80188 memory map i.e. at F8000 hex.
octet-stream - 32.00 kB - 03/02/2019 at 20:40
Download
J090-U11.JED
Programming data for IC11.
jed - 2.94 kB - 02/24/2019 at 20:28
Download
J090-U11.EQN
IC11 decompiled.
eqn - 743.00 bytes - 02/24/2019 at 20:28
Download
J090-U9.JED
Programming data for IC9.
Download
J090-U9.EQN
IC9 decompiled.
eqn - 877.00 bytes - 02/24/2019 at 20:28
Download
Arcom_J090_SC88T.pdf
User manual. NB my board is version 1 issue 3, and the manual is for board version 2 issue 5. The latter has the SCC in a PLCC44, and has EMC components (chokes on the RS232 lines, reset input, power rails etc).
Adobe Portable Document Format - 647.04 kB - 10/24/2018 at 23:34
Preview
