STEbus 80C188
80C188 processor board renovation
Reverse engineering of a tried and tested commercial board. Not my design!
I have the manual and circuit diagram of a slightly later version, which had the SCC in a PLCC package and added EMC muffling components such as small inductors in the reset-switch connector. PAL chips have been read and analysed.
The 80C188 is no longer made, but still reasonably available on eBay.
Working and running code.
Logic chips programmed, now thinking how to get test code running.
J090_SC88T_test_program_2019-04-08.zip
Latest source code
Zip Archive - 128.12 kB - 05/07/2019 at 01:54
Download
J090-U9.PLD
First attempt, compiles but unproven so far.
pld - 4.07 kB - 03/17/2019 at 20:48
Download
J090-U11.PLD
pld - 2.58 kB - 03/17/2019 at 20:48
Download
J090-U11.lst
Logic compiler output.
lst - 4.36 kB - 03/17/2019 at 20:48
Download
J090-U9.lst
lst - 7.00 kB - 03/17/2019 at 20:48
Download
View all 14 files
  • Firmware
    Keith02/24/2019 at 20:27 3 comments
    2019-02-24
    I need to get some test firmware running. Traditionally one might fit a monitor or BASIC but I think that all I really need is a simple monitor that can download intel hex files and run them. A monitor could have a command letter (like 'L') to load a hex file, but why not have the monitor handle any line that begins with a colon as a line of intel hex file?
    I will need to write a routine that handshakes the incoming data stream so it does not get choked while handling characters. I did that recently for the Zilog DART on a Z80 board. This board uses the more advanced Zilog SCC.
    This looks a reasonable starting point:
    http://web.archive.org/web/20130823172544/http://www.kmitl.ac.th/~kswichit/C188/boot.asm
    This looks like a good online assembler:
    http://www.compileonline.com/compile_assembly_online.php
    And there's probably some way to cross-compile from Linux, so I'm not worried about tools.
    2019-03-02
    8088 disassemblers seem to have no common syntax. Some disassemble to mov src,dst and some to mov dst,src, and many other issues, so it has been a headache disassembling a fragment of code and reassembling it. I shan't spend any more effort on trying to analyse the firmware if it is easier to write my own. I am using nasm under Linux.
    I put the demo code from the manual through nasm, and there were many syntax differences. Nasm is a more sophisticated assembler, and so things like locating the code are done by the linker, not by .org statements. Mind you, this is also true when using the as65 assembler from the cc65 package.
    The demo code was scanned in very low-resolution grayscale and is very hard to read. I have made best guesses where letters could be zero, O, C or G etc. With potential transcription errors and not knowing what nasm is up to, it is unlikely to work without a lot of human work.
    I need some ready-tested code to port, or check the manual demo code very carefully.
    2019-03-17
    Time to try some test code. There is some in the manual, very blurred, so I OCR'd it as best I could. My usual assembler (https://www.asm80.com) does not support the 8088, but there is an assembler that does - NASM. It can be used online (https://www.tutorialspoint.com/compile_assembly_online.php) but was easy to install on my Linux PC.
    I've got the manual's demo code assembling but can't be sure it is generating correct code.
    2019-03-24
    I realised the reason I heard nothing from my 80188 board was that the serial port connector pinout is completely different from the PC serial port. Doh! I used an adapter to get the signals properly connected, and I got this sign-on message:
    ----*****<<<<< Arcom SC88T initialisation v1.0>>>>>*****----
                     0016K bytes of memory
    Hurrah! Now I know that the logic chip equations are not disastrously wrong, and the board is fundamentally sound.
    This is from the ROM that came with the board. It still hangs after sign-on, probably trying to talk to boards that are not there. Hanging in a wait-state is the correct response to that. I am confident that the board is working well enough that if my self-made software is not working, it is probably a software bug.
    2019-04-06
    The firmware seems organised like so:
    FFFF:0000 jumps here at hardware reset
    FFF0:0000 jumps here next, 4K of initialisation code and a C run-time package.
    When done, does this endless loop:
    loop_1:
    call word 0xf800:0x0
    jmp word loop_1 ;
    which is calling the code at the start of the 32K ROM, at F8000.
    I presume this is the entry point for the application code.
    However, if I try to write an alternative application, whatever I write crashes. This includes just a simple RET instruction. So calling code in another segment fails.
    I wrote some simple code to see it was still okay running experimental code in the same segment. Fortunately there is plenty...
  • PAL chips read
    Keith02/24/2019 at 20:25 0 comments
    2019-02-22
    JEDEC files for the two PAL chips arrived, thanks to Andy!
    2019-02-23
    JED files decompiled. A bit worried the pinout might differ from the manual I have (for a later version hardware). Partly a red herring, the decompiler produces expressions for i/o pins that are used as inputs, but the output is disabled so there is never a conflict. I did find some difference in the rest of the circuit but I don't have to worry about that for the purpose of recreating the logic chips.
    2019-02-24
    I now have a better understanding of what is going on in the PAL chips. I already have ideas to tweak it to use a 512K RAM chip (instead of two 8K or 32K chips). It has two 8K chips right now, which is fine for testing but one might like to do something more serious.
    2019-03-14
    Translated the logic files, compiled them with WinCUPL and programmed two 16V8 chips which I put in the board with the ROM that came with it. Nothing came through the serial port, which may be normal since I don't know what the ROM was meant to do. The 8 MHz CPU clock is being halved for the SCC clock, so that is one thing that is definitely right. The CPU is being held in a wait state, because it is doing a read cycle with none of the programmable chip selects active, which becomes an STEbus cycle. As there is nothing there, it waits forever. This may be normal too, since I don't know if it expected a slave board there.
    For now I will just have to assume the logic is correct and use test code to prove or disprove it.
View all 2 project logs
tomcircuit wrote 12/09/2020 at 19:39 point
If you're still looking for a good source for a monitor/loader program for your SBC, I can highly recommend Dave Dunfield's XTOOLS package. It contains very good monitor program source code for a LOT of common CPU/MCUs. I've used the 6809 and 8086 and Z80 programs and they are very good and very easy to target to your own hardware.  I'm just a very satisfied user :-)
DDS Products (themindfactory.com)
