1Prepare Instrument Body
Cut two pieces of hobby grade plywood into rectangular pieces, 2"x20", drill holes for furniture tacks and body spacers
2Solder Main Board
Solder Teensy, IMU, pressure, and capacitive touch breakout boards to proto board. Attach board to main body, route tube to top of device, solder keys to the MPR121 touch inputs.
3Flash Teensy
Download and flash the .ino file to the Teensy
4Setup Windows based Synth
Install Reason and necessary rack extensions. Download .cmb file from files and open into Reason. Add the Teensy to Reason as a MIDI input device
5Play
Play some funky music.
J. M. Hopkins
