One of my theories for effective methods of rapid PCB prototyping is EDM, or electro-discharge machining. The idea behind EDM is that you have an electrode hooked up to negative voltage, dunk the system in a high impedance fluid, and then put a potential on the metal workpiece. When that electrode is close to the metal and the potential is high enough to ionise a path through the dielectric fluid, an electric arc gets created between them, taking out a chunk of your workpiece.
Basically a spark welder to remove material.
This is often used for removing broken taps from holes or machining very deep, narrows holes with high precision.
I think I can use this to directly erode paths between traces on a sheet of copper-clad.
EDM is one of those strange niche tools that only machinists are really into. The hardcore kind of machinists that don't really internet well. There seem to be about three resources on the internet for details on the inner workings of these machines: one CNC forum, one thread of a 3D printing forum, and one Yahoo group. None of these are particularly fantastic.
Fortunately, machinists are a lot more into books. Robert Langlois put out a couple how-to manuals in the early 2000s, and Ben Fleming has some much more recently.
Someone got in contact with Langlois recently, and he said that he lost interest in the project, but would definitely like to see Raspberry Pi control of an EDM and is open sourcing his books. So, naturally, I've read his books. I've also found some academic papers and expired patents that go over some design constraints.
There really are three major building blocks in building one of these: a CNC platform, the dielectric fluid immersion tank, and the electronics. The mechanical guys have got the first two figured and polished to a degree that I'm not capable of. The circuitry, though, is all extremely simple. I think I can add some microcontroller controls and improve hugely on the designs.
Most of the EDM schematics out there are just rectifiers and 555 timer-based pulse circuits.
One of the more sophisticated designs out there, The Garden of EDM by C. Scott Ananian provides an excellent rundown of design decisions, and has some similar ideas to what I've come up with independently. His version seems a unnecessarily complicated, though. Especially considering he never actually built his circuit. I'll start with a much simpler design, offload more to a microcontroller, and end up with more control out of the deal.
Here are some parameters I'm trying to hit:
20-100kHz pulses
20ns rise times or better
Adjustable voltage up to ~80VDC
4A max current discharge
I put all of my polished-ish stuff up on my website (left), but I'll be experimenting with this format for a daily-blag type thing. I'll try to throw up a picture and a few words every time I get to work on this.
Jarrett
Derek F
CriptasticHacker
core weaver
Mangus Tiranus
I would like to incorporate an optocoupler to separate the spark generator from the rest of the circuit. (Hopefully the benefits are obvious.) If someone with circuit design experience is interested please let me know and we chat via discord.
