Here it is, ready to be 3D printed along with the laser alignment guide, this version will be made out of Nylon-PA12 and dyed glossy black (polished), same with the alignment guide block.
Below is the drwaing for the Main Raman probe unit
Below is the drawing for the alignment guide (laser)
I will uploading the .STL mesh files for this shortly...
David H Haffner Sr
