Hackaday.io Hackaday.io
Sign up Log in
EasyIoT framework
EasyIoT framework is cheap, reliable, secure IoT framework build from Raspberry Pi, Arduino and various sensors and transcivers.
easyiotEasyIoT
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
46.1k views
5 comments
12.6k followers
  • Description
  • Details
  • Files 0
  • Components 12
    • View all
  • Logs 18
    • View all
  • Instructions 0
  • Discussion 5
View Gallery
46.1k
5
12.6k
122
Team (5)
  • easyiotEasyIoT
  • asaamaraaasaamaraa
  • walt-hickmanWalt Hickman
  • mahdi110hoo110mahdi110hoo110
  • baba13baba13
Join this project's team
  • http://iot-playground.com/
  • EasyIoT framework
  • EasyIoT YouTube channel
hardware
Software
ongoing project
arduino raspberry pi Sensors iot wireless nrf24l01 ESP8266 EasyIOT
Related lists
Atmel Arduino Projects
Arduino is an open source hardware platform for making interactive objects that can sense and control the physical world.
Raspberry Hacks
Projekte mit dem Raspberry Pi und Pi Zero
Mesh Network Intrnet
Network mess, conet ect
This project was created on 11/20/2014 and last updated a year ago.
Description
This is IoT (internet of things) project. Our goal is to create complete HW and SW framework easily to use by everyone with little technical knowledge. Basic requirements for EasyIoT framework: -secure - we don't want our neighbor (or stranger 1000 km away) switch on/off our lights :). -reliable - no need additional explanation. -cheap - we want build our system from components easily available on market for low price. Typical sensor costs 10 USD. -access to our system from everywhere with different connection options. we want all systems on our server. We don't want to depend on external cloud services. We -want our data stay ours - no NSA sniffing :). Of course if we want we can share our data with external services, but only if we want. -low power consumption - our system runs 24/7 so we dot't want to increase our electricity bill because of that. We also want to run our sensors on batteries at least one year (sometimes even 5-10 years).
Components
  • 1 × Raspberry Pi or Windows machine
  • 1 × Arduino
  • 1 × NRF24L01 module Fore Raspberry Pi and sensor nodes
  • 1 × Voarious sensors Wil be explained later
  • 1 × USB g3 modem strick (optional)
View all 12 components
Project Logs
Collapse
  • NRF24L01 (MySensors) Arduino balcony garden irrigation controller
    EasyIoT • 07/03/2015 at 13:22 • 0 comments
    Added NRF24L01 Arduino balcony irrigation controller tutorial.
  • ESP8266 WiFi gas sensor
    EasyIoT • 05/22/2015 at 14:24 • 0 comments
    Added new ESP8266 WiFi gas sensor tutorial.
  • ESP8266 PIR motion sensor (Arduino IDE)
    EasyIoT • 04/28/2015 at 21:03 • 0 comments
    Added new tutorial ESP8266 PIR motion sensor
  • ESP8266 WiFi DS18B20 temperature sensor (without Arduino, Arduino IDE)
    EasyIoT • 04/20/2015 at 10:28 • 0 comments
    Added ESP8266 DS18B20 temperature sensor tutorial.
  • ESP8266 relay switch (Arduino IDE)
    EasyIoT • 04/09/2015 at 15:46 • 0 comments
    ESP8266 relay switch without Arduino. Program written in Arduino IDE
  • ESP8266 NodeMCU door/window sensor
    EasyIoT • 04/01/2015 at 06:39 • 0 comments
    Added new ESP8266 NodeMCU door/window sensor tutorial.
  • EasyIoT low power sensor board
    EasyIoT • 03/17/2015 at 12:46 • 0 comments
    Now we working on EasyIoT low power sensor board. It's size is 18x32mm and it's suitable for remote sensor nodes like door/window sensor, button, water leak sensor, soil moisture sensor, temperature and humidity sensor... Sensor node can easily operate between 5 and 10 years on 2 AA batteries.
    Water leak sensor build by EasyIoT low power sensor board.
    Current consumption 5.8µA.
  • WiFi touch screen thermostat
    EasyIoT • 03/13/2015 at 20:45 • 0 comments
    ESP8266 WiFi touch screen thermostat is example of complex sensor build by ESP8266 EasyIoT Arduino library. We will use Arduino Mega 2560 and TFT 3.2" touch screen display. You will be able to access and control thermostat securely from remote locations.
    More details on WiFi thermostat.
  • ESP8266 LED dimmer
    EasyIoT • 02/24/2015 at 08:36 • 0 comments
    Added ESP8266 LED dimmer tutorial.
  • Added automation tutorial
    EasyIoT • 02/07/2015 at 14:30 • 0 comments
    We added EasyIoT server automation tutorial.
View all 18 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
zR3q wrote 02/27/2024 at 16:44 • point
IS there an option to connect this image with homebridge? im currently working on a homemade system and i want to connect my server to apple homekit.
pescoonlinebill1 wrote 10/16/2023 at 10:24 • point
Strange question: would an ESP-01 equipped with a wifi to serial bridge function in this manner, where the wifi encryption would shield the modules from unauthorised access?
pesco online bill
yOyOeK1 wrote 12/05/2022 at 19:49 • point
Nice!
warhawk-avg wrote 10/02/2019 at 07:20 • point
Crazy question..would a ESP-01 with wifi to serial bridge work...this way the wifi encryption will prevent unauthorized fiddling with the modules?
https://github.com/jeelabs/esp-link
electrobob wrote 08/18/2015 at 18:19 • point
Very interesting!
Is there any encryption over the NRF radio link?
Add a new sensor known as DS18B20 Temperature Sensor to your Arsenal. Robustness and Accuracy are some of its special abilities.
Project Owner Contributor
DS18B20 Temperature Sensor with Arduino ESP8266
akarshagarwal98akarshagarwal98
Protect your projects by making them fingerprint-secured with sleek, compact and fast ID809 Capacitive Fingerprint Sensor.
Capacitive Fingerprint Sensor with Arduino and ESP
Wireless esp-8266 based temperature, air humidity and air pressure sensor.
ESP-8266 based wireless sensor
charles-alvesCharles Alves
ESP8266 based soil moisture sensor Wi-Fi enabled.
ESP Soil Moisture Sensor
yancanyancan
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "EasyIoT framework", please tell us the reason.
Send message
Remove Member
