MIPI DSI Display Shield/HDMI Adapter
Back to project overview
A controller for LCD/OLED screens with MIPI DSI interface. Arduino shield format, HDMI-to-DSI adapter & built-in framebuffer.
twltwl
toferzim wrote 05/27/2018 at 22:17 point
Hello! Where can I get the PCB design? Can I flash it with Arduino as a programmer?
Djon wrote 12/17/2016 at 16:59 point
I can not generate rev1.xise firmware, somebody did it? Thank you!
Djon wrote 12/16/2016 at 16:05 point
Hello everybody! Does anyone have any ready rev1_top.bit file?
Freezingcold wrote 02/01/2016 at 03:37 point
I need to buy one of these ready built and that would be amazing. But not as amazing as building the thing in the first place.
I need to build a portable 1080p monitor 5" preferably. E980 looks perfect to use.
Think I need help don't I need hot air  soldering iron for these size of components?
5ydc wrote 04/13/2015 at 10:59 point
How can i order full project hardware? Cuz my circumstance does not allow me to build it!
Gonzalo wrote 03/08/2015 at 15:28 point
I love your project. I want to know more about this project so I want to know if I can ask more. I want to take this project as reference about how to implement FPGA real application interface, you should work at hardware because what you did is not easy at all. So it's really a study case. Great work!
I would love to interface the same way with a mobile camera module. I'm reading that Raspberry PI has a DSI and CSI2 (Camera Serial Interface), so it should be possible to connect it to a Display without using HDMI, I mean directly with the ribbon cable. And also a camera Module to the CSI2 directly.
Do you think it's feasible? Maybe using the spartan chip can be done both with your card. Doing slight modifications.
How much time did you take to make this project?
penny.lane.mini wrote 09/01/2014 at 23:14 point
Hi just wondering if the board supports touch as well?
I was hoping to use a mobile screen for an odroid
