FUTURE PLANS
01/06/2015 at 20:43 • 0 commentsAfter my college exams (which start in a few days) I intend to return to this project,. I intend to add a few more languages to be supported and also add the option to create ascii art comments in a selected language besides just created printable statements.
SOURCE CODE
01/03/2015 at 21:27 • 0 commentspackage printscii; import java.awt.List; import java.io.File; import java.io.FileNotFoundException; import java.io.PrintWriter; import java.util.Scanner; /** * * @author TAIBHSE */ public class PrintSCII { /** * given a file containing text, this * method returns an array list of each line of the file * @param file * @return * @throws FileNotFoundException */ public static List readFile(String file) throws FileNotFoundException { Scanner s = new Scanner(new File(file)); List list = new List(); while (s.hasNextLine()) { list.add(s.nextLine()); } s.close(); return list; } public static void intro() { System.out.println(""); System.out.println(" ##################################################################################################"); System.out.println(" ##################################################################################################"); System.out.println(" ### __,__ ###"); System.out.println(" ### .--. .-\" \"-. .--. ###"); System.out.println(" ### / .. \\/ .-. .-. \\/ .. \\ ###"); System.out.println(" ### | | \'| / Y \\ |\' | | ###"); System.out.println(" ### | \\ \\ \\ 0 | 0 / / / | ###"); System.out.println(" ### \\ \'- ,\\.-\"`` ``\"-./, -\' / ###"); System.out.println(" ### `\'-\' /_ ^ ^ _\\ \'-\'` ###"); System.out.println(" ### .--\'| \\._ _ _./ |\'--. ###"); System.out.println(" ### /` \\ \\.-. / / `\\ ###"); System.out.println(" ### / \'._/ |-\' _.\' \\ ###"); System.out.println(" ### / ; /--~\' | \\ ###"); System.out.println(" ### / .\'\\|.-\\--. \\ \\ ###"); System.out.println(" ### / .\'-. /.-.;\\ |\\|\'~\'-.|\\ \\ ###"); System.out.println(" ### \\ `-./`|_\\_/ ` `\\\'. \\ ###"); System.out.println(" ### \'. ; ___) \'.`; / /\'\'\'\'\'\'\\ ###"); System.out.println(" ### \'-.,_ ; ___) \\/ / / ___ \\ ###"); System.out.println(" ### \\ ``\'------\'\\ \\ ` / / / \\ \\ ###"); System.out.println(" ### \'. \\ \'. | ;/__/ / \\ \\ ###"); System.out.println(" ### ___> \'. \\_ _ _/ , / \\__/ ###"); System.out.println(" ### .\' \'. .''''''''/ |--\'`~~~~\'\' ###"); System.out.println(" ### _____// / .---\' _/ / / /__ _____ _____ _____ ###"); System.out.println(" ### | ___((_(_/ (_) |(_(_(_|___|/ __ \\|_ _||_ _| ###"); System.out.println(" ### | |_/ / _ __ _ _ __ | |_ \\ `--. | / \\/ | | | | ###"); System.out.println(" ### | __/ | __|| || _ \\ | __| `--. \\| | | | | | ###"); System.out.println(" ### | | | | | || | | || |_ /\\__/ /| \\__/\\ _| |_ _| |_ ###"); System.out.println(" ### \\_| |_| |_||_| |_| \\__|\\____/ \\____/ \\___/ \\___/ ###"); System.out.println(" ### ###"); System.out.println(" ### CREATED BY TAIBHSE ###"); System.out.println(" ### ###"); System.out.println(" ### ------------------------------------------------------------------------- ###"); System.out.println(" ### | INSTRUCTIONS | ###"); System.out.println(" ### |-----------------------------------------------------------------------| ###"); System.out.println(" ### | 1) Provide input file to convert to print statements, | ###"); System.out.println(" ### | e.g. C:\\someFolder\\file.txt | ###"); System.out.println(" ### | | ###"); System.out.println(" ### | 2) Type name of language to create print statements for, | ###"); System.out.println(" ### | e.g. Java, python, batch | ###"); System.out.println(" ### | | ###"); System.out.println(" ### | 3) Provide output location to save file to, | ###"); System.out.println(" ### | e.g. C:\\folder\\giveFileName.txt | ###"); System.out.println(" ### ------------------------------------------------------------------------- ###"); System.out.println(" ### ###"); System.out.println(" ##################################################################################################"); System.out.println(" ##################################################################################################"); } /** * @param args the command line arguments */ public static void main(String[] args) throws FileNotFoundException { intro(); Scanner in = new Scanner(System.in); System.out.print("INPUT FILE: "); List ascii = readFile(in.nextLine()); System.out.println("##################################################################################################"); System.out.println("AVAILABLE OPTIONS ARE: java, python, batch"); System.out.print("LANGUAGE: "); String selection = in.nextLine(); System.out.println("##################################################################################################"); System.out.print("OUTPUT FILE: "); PrintWriter out = new PrintWriter(in.nextLine()); System.out.println("##################################################################################################"); String[] java = {"System.out.println(\"", "\");"}; //first item is start of print, second item is end of print String[] batch = {"echo ", "echo. "}; //first array item is for normal print, second is to print blank lines String[] python = {"print (\"", "\");"}; //first item is start of print, second item is end of print //loop to replace special characters and add print statements for(int i = 0; i < ascii.getItemCount(); i++) { if(selection.toLowerCase().equals("java")) { //add beginning and ending print elements and escape all special characters ascii.replaceItem(java[0] + ascii.getItem(i).replace("\\", "\\\\").replace("\"", "\\\"").replace("\'", "\\\'") + java[1], i); }else if(selection.toLowerCase().equals("batch")) { //test if line is empty if(ascii.getItem(i).trim().equals("")) { //if line is empty replace with echo. //which is used to print blank lines in batch ascii.replaceItem(batch[1], i ); }else { //if line is not empty then append echo to start and escape all //special characters ascii.replaceItem(batch[0] + ascii.getItem(i).replace("%", "%%").replace("^", "^^").replace("&", "^&").replace("<", "^<").replace(">", "^>").replace("|", "^|").replace("'", "^'").replace("`", "^`").replace(",", "^,").replace(";", "^;").replace("=", "^=").replace("(", "^(").replace(")", "^)"), i); } }else if(selection.toLowerCase().equals("python")) { ascii.replaceItem(python[0] + ascii.getItem(i).replace("\\", "\\\\").replace("\"", "\\\"").replace("\'", "\\\'") + python[1], i); } } //print all lines to output file for(int i = 0; i < ascii.getItemCount(); i++) { // System.out.println(ascii.getItem(i)); out.println(ascii.getItem(i)); } //close print writer out.close(); in.close(); } }
IDEATION
01/03/2015 at 17:19 • 0 commentsSo the idea is to have a command line tool that takes in a text file and creates printable statements for a selected programming language from that file, line by line. The idea is that I can create the ASCII art or text in a file without having to worry about manually placing each line into a print statement or worry about having to escape special characters for the selected language, this tool should carry all that out for me.
