Hackaday.io Hackaday.io
Sign up Log in
Light Glove - Pro Trinket + ESP8266
A glove built with Pro Trinket and ESP8266 that catches color and throws it as MQTT message for other devices to consume
mohanMohan
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.5k views
0 comments
431 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
View Gallery
2.5k
0
431
5
Team (1)
  • mohanMohan
Join this project's team
  • Blog Post
hardware
completed project
mqtt ESP8266 element14 Pro trinket TCS34735
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 01/04/2015 and last updated 11 years ago.
Description
I built this glove as part of the Element14.com 2014 IoT holiday lights contest. I used a Adafruit Pro Trinket, a color sensor and ESP8266 to catch the colors and send it out as MQTT messages that can subscribed by other devices with MQTT capabilities. ( for example a LED wall washer or a LED Strip driven by a Arduino Yun or other WiFi capable devices. ) It can be easily modified to use other communication protocols instead of mqtt. The full build log is at here at element14.com http://t.co/N4yPzvOmlH
Components
  • 1 × Adafruit Pro Trinket 5v
  • 1 × ESP8266
  • 1 × Adafruit TCS34735 Electronic Components / Misc. Electronic Components
  • 1 × Flex Sensor Electronic Components / Misc. Electronic Components
  • 1 × Resistor and other necessaries
Build Instructions
Collapse
  • 1
    Step 1
    Instructions and source code links at http://t.co/N4yPzvOmlH
View all instructions
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Make your ideas come true!
Project Owner Contributor
Ever been drawn to those colorful little lights?
ai-thinkerAi-Thinker
The 2016 Hackaday Prize
Sub $10 RGB LED Mood light that you can control over WiFi embedded HTTP web server
RGB WiFi Web controlled LED Mood Light
jovanJovan
2021 Hackaday Prize
Color Identifier can identify the color of clothes (and other household), tell the color and what other colors is compartible with this one.
Сolor Identifier for visually impaired people
sergei-v-bogdanovSergei V. Bogdanov
Basic LED matrix connected to MQTT via ESP8266 for retro IoT
InfoMatrix
mihaMiha
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Light Glove - Pro Trinket + ESP8266", please tell us the reason.
Send message
Remove Member
