1Step 1
Create Joystick
Place your potentiometer atop your Parallax. Next, take your joystick controller and affix it to the potentiometer. You will then mount your Parallax to the breadboard.
- Materials
- What the joystick looks like under the knob. Just two Potentiometers
- Potentiometer Alternative View
- Place Potentiometer onto Parralax
- Attach Joystick to Potentiometer
2Step 2
Attach Breakout Board to Wires
- After mounting the Joystick Parallax to the breadboard, place your breakout board to then set your wires to corresponding units.
3Step 3
Placing Wires
- Connect green wire to D- of breakout board and L/R of Parallax (Left and Right motion).
- Connect yellow wire to D+ of breakout board and U/D of Joystick Parallax (Up and down Motion).
- Connect black wire to GND of the breakout board and GND of Parallax.
- Connect red wire to VCC of breakout board and U/D+ on Parallax. Connect this also to the L/R+ part of the joystick too
- Take the Final Small Red Wire & Connect to the Parallax's L/R Horizontally
- Final!
4Step 4
Plug In Code
Plug in the Mod's USB to your computer, and click "Run on Arduino" in the embedded sketch below. This will enable the Mod to detect your controls from the Joystick.
blorgggg
