Current status. Much is actually done but still it's not finished yet.
02/17/2015 at 21:25 • 0 commentsCurrent status. Assembled. Will be done some day. See the dust on servo motor :)
- Connections:
- 2 LDR-sensors (one for indoor ambient lightning, other for outdoor ambient lighting)
- USB for power but also programming when needed
- 2 push buttons for "manual mode" (Up and down)
- On/Off -swing switch for changing between "manual/calibration and automatic modes"
- PWM of the servo is controlled based on the difference between LDR-sensor values.
- To do still the optimization and proper working of the Auto/Manual switching. So actually much is done and this will be done one day...
- Connections:
