"Here is a crazy idea for interfacing web pages to the real world. Imagine an old SmartPhone sitting in a cradle on a robot or other hardware device. On the phones browser, a web page is pulled up with a Javascript program running that is changing two blocks on the screen from black to white. One block is the clock line, the other is data, and they transmit 2wire (Unidirectional I2C) data. In the cradle, at the bottom of the phones screen, a pair of optical sensors convert the light level into voltages in two wires which then connect to any I2C device (e.g. a servo controller^, D2A, uC, whatever).
Now you have a Javascript controlled robot with wifi connection, maybe camera, screen space for faces or whatever, audio, etc... And optocoupled so there is no danger of frying the phone. No need to root the phone, no need for any apps, no development environment other than a text editor.
Can't post Javascript here, so go to the link and press the "Send" button to see the blink'n'light
This idea is very much a solution in search of a problem, and now there is a problem that is worthy of being solved this way. A robot that is cheap as dirt, but as smart as the average SmartPhone, with all the phones sensors available to detect collisions and tipping (accelerometer) and direction (compass) and position (GPS) and recognize objects and avoid obstacles (camera, possibly with the laser line structured light trick and with cloud services or even vision in the browser via OpenCV.js) all while retaining the WiFi connection to the net for true teleoperation. More about that here:
These are untested and I would very much like your feedback on them. If you see bugs, please let me know. The silence on this project has kept me from devoting any time to it, but please know that if you ask, I will respond and make corrections, etc...
I'd really like to work on a design for a little board to interface between either a shift register or a microcontroller. My idea is that perhaps one board can be made to serve both functions. e.g. You populate part of the board for I2C, and you populate a different part for a shift register.
The other option is to do two separate boards, in which case I would do the I2C to uC version first. It would be something like my RC Servo to uC adapter board: https://hackaday.io/project/181972-rc-servo-adapter but with locations to mount the electronics and 2 light sensors, either directly to the PCB or via wires. (note to self, remember to include strain relief holes. I always forget those).
If a final circuit for a shift register is tested, then I'll try to include a 3rd sensor and use one edge to pinout for a shift register chip.
My friend Conrad soldered up a permanent version of the breadboarded circuit and gave it to me. Next is hooking it up to an Arduino and testing the transmission of data for accuracy and speed.
For example, if someone says, "As stated on page 10 of the report," it means that the specific information being discussed can be found on the tenth page of the mentioned report. https://techzone-agency.com/
nformation effectively, and ensuring proper HTML markup, on-page optimization aims to make the webpage more accessible, relevant, and appealing to both search engines and https://techzone-agency.com/
Morse code was designed for humans to decode. You could probably use a better and more efficient (not that it matters in this use case) encoding such as those used in remote controls and throw in some error detection/correction as well which is more salient.
Here's an idea for going the other way (getting data into a cell phone from an LED on a device)
Let's say you setup your IOT device (ESP, whatever) to talk to your router at your home. Now you need to figure out what IP address your home router assigned. Some of us can log into the router to see the DHCP table, but some routers are locked down, etc... There are programs that will scan the IP space, (e.g. FING) but another option is to somehow communicate the value from the bot.
Put that on a public web page (must have HTTPS, not HTTP) and then users can go to the web page, allow access to the camera, hold the camera over the robot, get the web URL decoded, and then click on it to connect directly to the robot!
Users don't even need to know that it's using morse code. But it's also sort of cool that it could decode any message.
