Raspberry Tor Router
Back to project overview
Connect your unsecured wireless stuff to the internet in a secure and anonymous way
Karmanya wrote 04/24/2019 at 20:22 point
@everyone who is having issues in making access point, refer to this and follow given instructions for making an access point:
https://raspberrypi.stackexchange.com/questions/88214/setting-up-a-raspberry-pi-as-an-access-point-the-easy-way
luipez wrote 02/07/2018 at 21:04 point
Sto eseguendo la tua guida e tutto ok fino al punto 5.
Al punto 6 dato il comando "sudo ./pifi.sh" la procedura si blocca dopo "Starting ISC DHCP server..." col seguente errore:
Cleaning up...
Starting hostapd service...
Job for isc-dhcp-server.service failed because the control process exited with error code.
See "systemctl status isc-dhcp-server.service" and "journalctl -xe" for details.
Checking hostapd status...
● hostapd.service - LSB: Advanced IEEE 802.11 management daemon
   Loaded: loaded (/etc/init.d/hostapd; generated; vendor preset: enabled)
   Active: active (exited) since Wed 2018-02-07 21:24:26 CET; 21min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 422 ExecStart=/etc/init.d/hostapd start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/hostapd.service
feb 07 21:24:20 raspberrypi systemd[1]: Starting LSB: Advanced IEEE 802.11 management daemo
feb 07 21:24:26 raspberrypi hostapd[422]: Starting advanced IEEE 802.11 management: hostapd
feb 07 21:24:26 raspberrypi systemd[1]: Started LSB: Advanced IEEE 802.11 management daemon
lines 1-10/10 (END)
e il cursore si blocca dopo (END).
Come mai?
I'm running your guide and everything is OK until point 5.
At point 6 given the command "sudo ./pifi.sh" the procedure is blocked after "Starting ISC DHCP server ..." with the following error:
Cleaning up ...
Starting hostapd service ...
Checking hostapd status ...
     Docs: man: systemd-sysv-generator (8)
  Process: 422 ExecStart = /etc/init.d/hostapd start (code = exited, status = 0 / SUCCESS)
Feb 07 21:24:20 raspberrypi systemd [1]: Starting LSB: Advanced IEEE 802.11 management daemo
Feb 07 21:24:26 raspberrypi hostapd [422]: Starting advanced IEEE 802.11 management: hostapd
Feb 07 21:24:26 raspberrypi systemd [1]: Started LSB: Advanced IEEE 802.11 management daemon
lines 1-10 / 10 (END)
and the cursor stops after (END).
Why?
edwardseton22 wrote 01/08/2018 at 16:00 point
i managed to get to the point of setting up the WiFi hot spot but i cant do the next step as the WiFi/Ethernet is disabled and i am having trouble enabling it, please help
Alvan wrote 01/29/2017 at 21:58 point
Thanks for the tutorial! I followed the instructions and I am able to see the wifi with other devices, but I cannot connect to it. Double checked the wifi password, everything seems to be correct. Any ideas what could have gone wrong?
Thanks!!
meir_zisu wrote 01/27/2017 at 22:49 point
I followed the instructions on RPI 2, but I am not able to see the new wifi, any idea why?
If my router is on 10.0.0.X range, Should I modify the script to setup 10.0.0.X address and not 192.168.X.X
Thanks,
mzisu
Jakub Simek wrote 12/30/2016 at 02:33 point
Hi,
thx for your tutorial, but I'm still running into one problem. Every time i try to install ISC DHCP, in the end of instalation it says:
'job for isc-dhcp-server.service failed.... '
'invoke-rc.d: initscript isc-dhcp-server, action "start" failed'
Can any1 pls tell me what to do? I tryed several tutorials, but every time this happend.
I use RPi2 B and TP-LINK - wn722n
ismaele wrote 11/24/2016 at 21:38 point
Hi Thomas,
I use a raspberry Pi 3, and i tried to install this software, but when i 've installed pifi, my wifi stopped working.
i tried to stop pifi, to reset wifi settings, and to update my file, but it still not working.
so how can i do to resolve this problem?
i hope you'll answer me
Ismaele
Dim wrote 08/18/2016 at 21:16 point
So are the connections issues solved ? Thx
Bucky wrote 07/17/2016 at 11:19 point
will a wipi work
barismert wrote 06/05/2016 at 15:52 point
Hello.
The scripts are ok with the raspberry pi 2 with TP Link WN725N wireless stick. There have been some errors with the first script but after rebooting the PI, ı can easily connect to AP very well.
After the second script I have checked  my ip using ipleak.net and it has been seen TOR exit node. So it is ok,too.
Is there a vpn kill switch configuration in the script that enables the network more secure?
Thank you very much.
Kind regards.
Henrik J wrote 04/22/2016 at 19:47 point
will this work with a raspberry pi 3? Is its onboard wifi an issue?
Alex wrote 05/16/2016 at 19:42 point
Henrik, I ran into some issues getting this set up myself (also on a Pi 3) and yes, you'll have to tweak certain things (for instance, the driver is different than the one that the linked hostapd script expects).  I followed this guide to get it set up as an access point:
https://frillip.com/using-your-raspberry-pi-3-as-a-wifi-access-point-with-hostapd/
Dim wrote 08/18/2016 at 20:51 point
Hi all
Did this worked ? Should I removed the dongle and go 4 that ?
Got a PI3 too ....
Thx
Dim
rhadax wrote 03/15/2016 at 22:45 point
Hi, after launch pifi.sh and reboot, i found my wifi but after connect i have restricted access and no internet.
And i found this error in my raspy :
not running dhcpcd because :etc/network/interface
defines some interface that will use a DHCP client  ... failed
Startpar: services returned failure: isc-dhcp-server ;.. failed
If you have some ideas ... i've tested all tuto with pifi.sh and no one works. PLease help me ;)
bazzinga wrote 03/03/2016 at 15:46 point
hi , i have the same problem, i have a Edimax wifi dongle, but i think the problem is somewere else because when i check the status of the hostapd, it's not recognised , and in /etc/init.d/ it does not return any instructions after a status or start query.
greenones wrote 03/03/2016 at 00:09 point
Hi!
So I get to this part:
Follow all the instructions on the screen. The script will reboot your Pi when it is finished
After the reboot I lose all network connections :P Any suggestions?
Thomas wrote 03/03/2016 at 08:14 point
Hey!  Look at the suggestion I gave someone else in the comments
section.  It is probably the same issue.  What brand of wifi dongle are
you using?
