Assembled and Testing
A project log for DerbyLink USB to RS232 over CAT5
USB to RS232 converter using RS422 over CAT5 as an intermediary. For my youngest son's Cub Scout pack to simplify Pinewood Derby wiring
tomcircuittomcircuit 03/17/2015 at 03:480 Comments
I finally received my PCB's today. The DirtyPCB service thoughtfully bundled all three board types I ordered (two for this project, one for the Rubidium Oscillator controller project). The board quality seems good. A slight registration error in the silkscreen on one of the boards, but really nothing worth complaining about. It's been a while since I've assembled HASL'd boards - I got spoiled by the ENIG finish that OSHpark provides.
I put together both boards in less than an hour, and other than having to diddle a resistor value in each of the 48V and 9V voltage comparator circuits, no issues. I think I simulated the comparator circuit with an incorrect value of reference voltage (derived from the 5V power LED) so I had to adjust the divider input R to achieve the correct threshold voltages (40V and 8V). I'll have to look into this to be sure.
I threw together a quick loopback test setup with the two DerbyLink boards, a 100-foot CAT5 patch cord, a 48V supply, and a 30-ohm load (300mA at 9V) to simulate the draw of the MicroWizard finish line. It's presently undergoing 'burn-in' in my basement lab. I found a nice COM port loopback test program, so I'll let that run overnight checking the USB -> RS422 -> RS232 -> RS232 -> RS422 -> USB link at bitrates between 2400...115200 bps.
