Hackaday.io - Capture & Log Mobile App
A project log for Hackaday.io Project
Follow for the 'Hacklet' and latest news about hackaday.io
Richard HogbenRichard Hogben 06/10/2019 at 20:1919 Comments
Keep your existing Hackaday.io projects up-to-date with your mobile device and this companion app. Capture photos of your hardware projects, caption them, and log your project progress.
How it works
Get started
Keeping regular logs of your ongoing hardware projects is the best way to take advantage of the community support and broad visibility provided by the Hackaday.io platform.
Use this app alongside your existing Hackaday.io account. Don’t have an account? Sign up at Hackaday.io.
The app is available for iOS and Android:
Android download link
iPhone download link
Logging in
Your existing Hackaday.io email and password are required to login. If you signed up with Twitter or Github these options are available at the bottom of the login screen.
If you have forgotten your password you can create a new password here.
Photos and editing
On the photo capture screen you can take a new photo or access the photo gallery in the top right. Rotating and crop tools appear after a photo has been captured.
Posting to a project log
Choose from an existing public or private project. Then select from an existing log or create and title a new log. New projects can be created here.
Logging out
From the home screen, click on your avatar in the top right to open the user menu. The menu contains a logout link as well as other options.
Feedback
For general app feedback or questions you can comment below or on the Hackaday.io feedback page.
matiassimonlesomar2000 wrote 10/13/2019 at 17:24 point
hello
AccidentalRebel wrote 10/10/2019 at 03:04 point
I tried it out and I like it. It's bare bones but it's easy enough to use that I can easily sneak it in my workflow.
Good job with this!
PeterS wrote 10/10/2019 at 01:05 point
btw the manula has been taken from Antlabs. https://docs.wixstatic.com/ugd/f5a1c8_d40d077cf5c24918bd25b6524f649f11.pdf
For political correctness, please, if you take other poeples files, tell where you have taken them from.
PeterS wrote 10/10/2019 at 01:04 point
Hi all,
Carlos Barrera wrote 10/09/2019 at 22:54 point
Designing Sci-FI: Interfaces sci-fi / Futuristic Idea  Rotary InFlow, Mechanically simple, Total Efficient Systems.
Conceptual Engineering Application, Detail Idea Tip/Technology Submission - State of the Art - Novel InFlow Tech - Featured Project Development; 1-Rotary-Turbo/Gearturbine, 2-One Compression Step/Imploturbocompressor:
Im Individual Inventor, and this is my Work. And I want to show, Here in this Great Site, Great Artist and Designers Platform, as a Conceptual Detail Idea Tip, To Present as New Technology Innovation, and see this Post info, in a way as a view of Designers Platform as a Conceptual idea, for a vehicle Performance System (Work use Application), as a power-plant and propulsion system, in a Novel way, (“Designing Futuristic Sci-FI if you want”). New Kind a Power-Plant, and a new kind a Propulsion to.
(Note; I make this post, as Idea of another different (new one) option, as a power-plant system novel kind. And here Because this concepts, can work to, and different kinds a flows, but I know still a project, And I just want a present in this platform, to show at people were know about atypical engines types, and power-plant and propulsion systems and  rotating machinery).
Featured Project Development - State of the Art Novel InFlowTech: ·1-Gearturbine RotaryTurbo, ·2-Imploturbocompressor One CompressionStep: |/ *1; Gearturbine Project, Rotary Turbo, Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD · With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses · 8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type. |/ *2; Imploturbocompressor; Imploducted, One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Imploducted Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is possible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature. http://stateoftheartnovelinflowtech.blogspot.mx/
Rob Mantanus wrote 09/23/2019 at 11:05 point
Good Day Everyone!
Would you like to visit our webpage: http://www.731roof.com
We are Cincinnati roofing contractors proudly serving our area since 2007. Our expertise and quality work have given us Master Elite and Select Shingle Master status with the highest quality roofing suppliers. As Cincinnati roofers, we understand that your home is more than just four walls and a roof, which is why we are also a premier siding contractor and window contractor. So the next time you are in need of roofing, siding, or windows, give us a call. Schedule your free estimate today!
Services:
-Roofing
-Siding
-Windows
-Gutters
-Commercial
edthelegendary wrote 09/22/2019 at 05:09 point
It will surely be better than the Instructables app. Lol. (No sarcasm intended. The Instructables app is terrible.)
davedarko wrote 09/19/2019 at 10:08 point
It only pulls projects from 2014 till 2017 for me :D the last one is the 433MHz MQTT thing, I presume it's capped somehow?
And after creating and posting a new log, the app crashed. Also the fire emoji was converted to a question mark.
Rocking a Samsung S6 edge, Android 7.0 - cool stuff though!
Michael Cullen wrote 09/15/2019 at 16:44 point
nice idea! It would be nice to be able to add logs without pictures though
manta103g wrote 09/09/2019 at 22:15 point
no comments
Miroslav Zuzelka wrote 09/09/2019 at 17:46 point
@Grant Giesbrecht + 1
+ I would love in this version to be able also create project and start to insert photos in it
kwapiszon wrote 09/09/2019 at 12:55 point
I would like have a account on mastodon on hackaday, cell phone ap? no not for me
omarmung wrote 08/21/2019 at 22:21 point
Nope, not yet.
Suren wrote 07/08/2019 at 19:55 point
..hi.... have anyone tried programming a single board esp32 lyra T for a webradio yet ?
Philip Ashmore wrote 07/04/2019 at 13:17 point
Is there a git repository for this? I'd really like to know the secret sauce to integrate photo capture to my Android app!
Richard Hogben wrote 08/21/2019 at 22:40 point
Whats your Android app?
Philip Ashmore wrote 08/22/2019 at 06:14 point
A solder oven controller, written in Qt so I can debug it on my laptop over serial.
On the phone it uses bluetooth.
It helps to see a picture of the oven on the background so you're using the correct PID settings.
Since it's a phone it would make sense to just snap a picture of a new oven in the app before calibration.
Grant Giesbrecht wrote 07/04/2019 at 03:15 point
Nice! I've always wanted a Hackaday app and I'm glad to see movement in that direction. I'd love to see a full-fledged app which lets you view and search projects, post comments, edit projects, etc.
Richard Hogben wrote 08/21/2019 at 22:41 point
Thanks! The current version is purposefully simple to gauge interest and further development.
