LCD and Analogue Skeleton Clock
Using an Arduino UNO a 20x4 LCD display and an analogue skeleton movement to make a portable master clock.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This clock is designed to backup my Master Clock should it fail or need maintenance and is portable with battery backup. It can also be used as a stand alone clock as well. This clock uses an Arduino 328 Microprocessor to decode Time from the DCF77 "Atomic" Clock in Mainflingen near Frankfurt Germany. Time is displayed on a skeleton clock and a Blue 4x20 LCD display. Clock pulses to drive slave dials are monitored on an LED panel. 3 x 1.5volt AA cells provide battery backup when disconnected from the mains. The main board has a USB to UART connector so the clock software can be updated from a PC or even a Mac. Full details including code on the Clocks Web page see link.
