11Step 11
Hot-glue the driver board to the back of the LCD (insulate the bottom first!) and make it as thin as possible.
12Step 12
3D print the front of the case and the button inserts.
13Step 13
Place the inserts in the front of the case.
14Step 14
Screw the controls (except analog sticks and triggers) into the front of the case and use ribbon cable to hook up the buttons.
15Step 15
Press the LCD in the appropriate cutout. Use hot glue to keep it in place.
16Step 16
3D print the back of the case.
17Step 17
Screw the joystick(s) and triggers to the back of the case and solder ribbon cable to them.
18Step 18
Flash the Teensy LC with the joystick firmware.
19Step 19
Solder the ribbon cables to the Teensy LC (make sure to keep it relatively flat!)
20Step 20
Cut up a USB cable.
