21Step 21
Solder one end of a USB cable to the pads on the bottom of the Teensy LC.
22Step 22
Glue the Teensy to the back of the case.
23Step 23
Cut the USB cable to size and solder the other end to the Raspberry Pi.
24Step 24
Connect +5v, GND, and composite video from the Pi to the LCD.
25Step 25
Attach wires to +5v and GND from the Pi.
26Step 26
Screw the Pi in place.
27Step 27
Use some superglue or hot glue to glue the switch in the cutout in the back of the case.
28Step 28
Solder the +5v and GND from the Pi to the PowerBoost 500c.
29Step 29
Solder short wires between the switch and the PowerBoost.
30Step 30
Screw the PowerBoost in place.
