31Step 31
Use hot glue to glue the underside of the battery in its cutout in the case.
32Step 32
Connect the battery's JST connector to the PowerBoost.
33Step 33
Double-check all your connections.
34Step 34
Test the case while open.
35Step 35
Fix anything that doesn't work.
36Step 36
Insulate any exposed circuits that might touch.
37Step 37
Fold the case halves together.
38Step 38
Screw the four case screws in.
39Step 39
Test the unit while assembled.
40Step 40
Step back and appreciate your hard work.
