• WiFi , pick and placing
    charliex05/22/2016 at 00:48 0 comments
    More parts. CR123a's and holders, CPU's
    Had to build a stencil holder
    custom made steel pins
    Picked the right diode it seems, I was worried since my board with two diodes wasn't doing well, but forgot we weren't using the logic level converter, added that and dropped the two diodes to one and works up to 7V , 6.4V is the highest with the
    Running in WiFi mode. Inside a ER20 tool holder box.. Music is quiet in the background but you can hear it later in the video.
    Continuing to build the stencil holder and start pick and placing. Built 8 badges by hand so far.
    6 days to go..
    Unfortunately we are low on ESP8266's since we gave them away like candy last year, and couldn't get them delivered in time.
  • All at once
    charliex05/15/2016 at 19:02 0 comments
    I had another crazy work year, so i was super behind on the Badge this year, i finished the eagle design a couple of weeks ago, and the PCB's arrived on Friday from DHL.
    I always run into the issue of scale when doing boards in eagle, and some of the logos didn't turn out as well as i wanted. In fact some of them (ours) are so subtle as to be called into question of existing.. So next year, lots more print outs., and possibly a larger badge
    Grabbed up all the spare components from last year, only missing the SMA diode( reverse protection and voltage drop) and the logic level inverter.
    I bought this battery charger from CVS or some such in San Francisco when I was at GTC, after a few days all it did was shine the LED's continually so I let it run out and decided to take a look inside, after opening the case carefully (threw it against the concrete floor) opened it to reveal this, oddly i have that same exact board from an aliexpress binge last year, but i digress.
    cool, as expected the 18650 and a charging circuit, so i carefully binned it , since who knew the state. Later I realised i know where I saw an SMA diode looking like an RP, so grabbed it back out of the bin , removed the diode and back into ewaste it went.
    Next was the level shifter, i thought i had a bunch lying around but nope, I had one board from last year ( i never actually got a full working badge as i swapped mine out with someone who destroyed theirs, which is now mine) it had a CPU, one LED and as luck would have it a level shifter, so pulled that off.
    "My" badge from last year... IC1 is what we want
    Great now the build out begins.
    sorting out components
    add some tools
    clear a 10cmx10cm space in the garage
    build the minimum components to get it to work, or so we think.
    NADA, zilch nothing.. sigh, panic read schematics..
    Wait, that board from last year i ended up with it, because it didn't work.. check level shifter. yep in but no out... OK find another, don't i have a level shifter on my old Xmas lights, yes, same package , yep! install it, nothing...
    Ok stop think, the problem with the old Xmas lights was they ran 400khz vs 800khz, why, slew in the level shift, because transistors and caps, not an IC.. so what was that IC, wait that is actually the 3.3V VREG.. ok damn.
    CPU's working, its doing the right thing. These boards can be daisy chained together, so lets run one from a Xmas light controller board.
    Success! OK lets try running everything at 5V vs 3.3V so no level shifter and jumper it.
    We did find out what the problem was, so more on that later, capacitance was our first issue.
    Tools grow rapidly to accommodate debugging
    Also we found an extra 2000 LEDs in the back office, that is just how we roll around here. 2000 WS2812Bs under a table in a box.
    Decently bright
    Next step getting the ESP8266 to work, i flipped around the connector compared to the XMAS lights i had pulled up. (in my defence there was like 10 things going on as i was doing this) and discovered i'd made the connector so the WiFi would be at the back pointing out. So that had to be desoldered ( solder sucker added to tool table) and put back, did that, still nothing. Ahh right added the extra GPIO's so put them to HighZ and we also added RESET, so made sure they were OK, still nothing , power LED is on now and the blue light is blinking. So it appeared to be working.
    OK Scope out check all the connections, seems to be OK but not working and ESP has been verified. Go back to schematic, this is Sunday morning so a lot less going on, and i think wait a second isn't that the very first rev of the xmas board that had the wifi going off the edge, yep, sigh so i had gotten it the right way around, desoldered the 4x2 idc header again and reinstalled, hey look its trying to connect to the WiFi , reset loop. Voltage issues, i suspect noisy as well since the ESP hates noisy power and i'm running it off the bench, the LEDs are working mostly but wrong colours and...
