For those interseted in the Dream SAM2695 chip, Modern Device just updated their Fluxamasynth Shield with it !
amazing good projetc ideam dream breakout just plug din midi jack so that control sound standart midi port devices
I have finished making pcb dream breakoutboard dream sam 2695 how to get midi port its standalone can be connected directly via midi in standard midi keyboard without any micocontroler ?
Great project. If you don't mind my asking, wWhat inductor did you use at L1 between 3V3D and 3V3A?
You are right, some information are missing :
- Y1 is a 12Mhz oscillator (TXC 7A-12.000MAAJ-T)
- U2 is a SOT23 LDO 3.3v voltage regulator (micrel MIC5225 or MIC5504)
- as I said any 6.3v capacitors should be OK, all 10uF are 1206 tantalum, but ceramic will works as well. I used X5R for 100nF
if I want to make a dream sam 2695 breakout any component should I buy besides ic dream sam 2605 and 5225 mic microchip especially in the picture iseperti y1, u2, C 22, C 14
when extrack and read my eagle software no details part component list volt detail
can you give me detail part list component volt detail please?
yes http://asimov.n0life.org/~julbouln/electro/dream_breakout.zip, but no detail part components list volt
@oshpark Thanks :) It is so easy to do design with 0.4 QFN thanks to your PCB service !
Thanks for your intereset ! schematics and layout are available here : http://asimov.n0life.org/~julbouln/electro/dream_breakout.zip
yes layout and your schematic no detail part list component detail volt
can provide the name of spare parts in detail what is needed to make this dream breakout?
can provide the name of spare parts in detail or biil of material component list what is needed to make this dream breakout?
SHAOS
Stefan Wagner
Dream Sam 2695 MIDI pin aout 4 pin MIDI Vin ,ground and 3,3 v conection tx ground Vin to 5v or 3,3 v
