Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Robot Arm | Interfacing 3Dconnexion Spacenavigator
Interfacing a 3Dconnexion Spacenavigator to Linux and mbed to control a small Robot arm built with Lego technic
MarkMark
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
10 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
908
1
10
6
Team (1)
  • MarkMark
Join this project's team
ongoing project
3Dconnexion Spacenavigator mbed raspberry pi robot arm USB Linux embedded linux lego
This project was created on 07/12/2015 and last updated 2 years ago.
Description
This Project shows an interface between 3Dconnexion Spacenavigator, Raspberry PI and mbed to control a small robot arm. This arm is built with Lego technic elements and Servos. This combination (mechanical and electrical side) enables very fast prototyping.
How To:
Raspberry Pi:
make a script that opens/read /dev/hidraw (USB interface to spacenavigator)
two line are given from this device. Use the first byte to identify them. Every axis command consists of two unsigned bytes. one for the main position and the second for the value.
After finding out the protocol, extract and calculate the main values. Define a SPI interface for sending the data to a microcontroller
No special libraries needed to compile !! I stored the script in /etc/rc.local/ to run it at the start up
mbed:
Define a SPI interface and get the values from R-PI.
Sending values to the servos
Details
Log In/Sign up to comment
Sign up with Github
OR
xmetrix wrote 01/21/2019 at 08:04 • point
Can anyone please share the script that reads /dev/hidraw*  and parses it into usuable information. thanks
A Linux-based smart boat powered by the PXFmini and the Robot Operating System.
Project Owner Contributor
Pi0Boat: A $250 smart boat with the pi zero
Víctor Mayoral VilchesVíctor Mayoral Vilches
We are building a robot maker community around vigibot.com allowing you to control anything you want over the internet with low latency!
Vigibot, the ultimate web remote controller!
mikemike
2021 Hackaday Prize
3D Printed Micro-Servo Hexapod
ZeroBug - DIY Hexapod Robot
Max.KMax.K
Meet Sid our office robot, take control and see how many points you can score!
Sid the office robot
Alex CrooksAlex Crooks
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "Robot Arm | Interfacing 3Dconnexion Spacenavigator", please tell us the reason.
Send message
Remove Member
