5x5 28BYJ-48 Grid
Artistic installation to be presented at the end of March 2018
0 followers
The challenge was to manage the 25 step motor control (the famous 28BYJ-48) using only one Arduino. I used shift register (74HC595) to recreate the sequence of movements and thus have the ability to stop 1 or more engines without affecting the movement of others. The code and the material were designed to be reused in another context, this first version uses a sequence that was pre-programmed in the micro controller.
  • About Dupont cable
    Veronique03/01/2018 at 17:56 0 comments
    I thought I did not have any problems using Dupont cables to make my connectors. Unfortunately they are not all of the same quality which brought me a lot of contact problems throughout the tests. I removed the insulating part of the connectors and tighten the pin with a pair of pliers. I will think twice about it next time I have 6 x 25 wires to manage.
View project log
