3D
A project log for 2.5-3D thing
a tiny-but-scalable three-ish axis-system *from* laser-cuts
eric-hertzEric Hertz 07/23/2015 at 14:571 Comment
This one's a stretch...
It certainly clears up the 3rd-axis clearance-issue, but:
* may be quite a bit more difficult to run the cables/pulleys
* might not be stable-enough for merely two casters on the 'bed', should I use four?
(otoh, now that I think about it, part of the niceness-discovered with the pulley/lego system was that the cables, when positioned and tensioned well, actually add to overall stability quite-nicely)
* appears to use quite a bit more material for the same travel-distances...
* more difficult to add support left-to-right... may need longer bed-casters...
* can't add front-to-back support in the front
* kinda bulky/ugly...
Nicities:
* lots of vertical clearance for potential 3D-stuff....
* easier to make the Y/Z carriages larger, to mount larger things (dremmel-tool?)
* The Z-axis should be *quite a bit* stronger
* (maybe the Y, as well?)
* The Z-axis carriage and associated cable-tensions might actually add some stability
things to think about...
Eric Hertz wrote 07/23/2015 at 15:09 point
Guess I'd be a fool not to use my new endeavors with the PIC32 to drive this system!
