Hackaday.io Hackaday.io
Sign up Log in
Geiger Counter Meter
Adding enhancements to a Spakrfun Geiger counter module
scoopsScoops
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
434
0
6
6
Team (1)
  • scoopsScoops
Join this project's team
hardware
ongoing project
geiger
This project was created on 07/27/2015 and last updated 2 years ago.
Description
I want to add a speaker and meter to a Sparkfun Geiger counter module. I wish they had broke out more pins from the microcontroller. I needed to add some wires to the pins. Here is what I have so far: https://youtu.be/S90JSTjxOEk I toggle the speaker on signal. The meter is connected to a PWM output and has a sum - decay function that adds a value on click and then slowly decreases. I need to add a scale control (low-med-high) so I don't pin the needle. And I need a nice box.
Components
  • 1 × Sparkfun Gieger counter module Seems discontinued :( https://www.sparkfun.com/products/retired/11345
  • 1 × Millamp Meter Found in ewaste
  • 1 × Speaker
Project Logs
Collapse
  • Missing Code
    Scoops • 12/19/2018 at 02:07 • 0 comments
    I need to find my code for this. Still looking where I saved it...
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
PLC ladder diagram for intelligent automatic stair lights, working by photocells and count instructions
Project Owner Contributor
Automatic stair lights
andrea-de-napoliAndrea De Napoli
in this project i will let you know the easiest way of preparing the bot which can be controlled through blue tooth.
control of bot using bluetooth module
surya-sai-manisettysurya sai Manisetty
Turns on my office lights whenever I'm at the computer and off when I'm not
Screensaver-activated Office Lights
ted-yapoTed Yapo
Building a reusable IR remote code learner and replayer on STM32
Learning IR codes
benedekkupperbenedekkupper
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Geiger Counter Meter", please tell us the reason.
Send message
Remove Member
