Glow Staff (MK2)
Currently a holding page until I have pics and details to write up... In short... it works and its awesome :-)
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A glow staff for circus related performances and just fun in the dark, based largely on one that I made some time ago for a performance group. SPECS: -Batteries: 2x protected 18650 li-ion cells, replaceable if needed -LEDs: 120 WS2811 leds arranged in 4 x 0.5 meter strips -polycarb chassis and outer (pretty indestructible-30ft spinning drop onto concrete) -1.4m length -flippin bright when on full white (based on prototype) -at least half an hour burn time (on full) -SD card for loading bmp files and sequences (txt files) -IR/RF remote control using APC220 modules -remote supports multiple devices (255) -charging port and power switch accessible from one end -programming port and programming switch accessible from the other end -supercap uC power backup in-case of momentary battery disconnect when dropped known issues (not fussed): -timing of ws2811 strip is not great, images not always in-line -file loading is noticeable in sequences in long exposure pics
