Shapeoko 3
Progress with my Shapeoko 3
I'm horrible for updating things so ask questions!
I try to provide info in my videos.
  • Limit Switches
    Emerica03/09/2016 at 10:10 0 comments
    A real limit switch kit, yay!
    Test it out!
  • Blocks, Name Tag, Guitar tests.
    Emerica03/09/2016 at 10:07 0 comments
    I finally finished the name tag that came with my cat tree.
    Also tried to cut some OGEL blocks but poor alignment and lack of homing didnt help. Time for limit switches!
    I also ended up trying some 3d stuff, again a super long video, mainly because I was lacking larger endmills.
  • Inlays Inlays Inlays
    Emerica03/09/2016 at 10:01 0 comments
    I ordered some glow powder from Ready Set glow, and some epoxy from Micheals.Sweet, came out nice!
    A shot duing the cure.
    Halloween Time!
    Long video but here's the cured outcome before sanding,
    Here is after some sunlight and sanding
    I painted it black and shall leave it with my rental when I leave ;)
    Pacmac needs to be chased by ghosts. THe cnc made short work of these.
    I'll leave them out all year. I drilled 4 holes in each and zip tied some dowels to them. Simple and cheap.Run pacman, RUN!
    Friend loves the punisher... It must be done.
    Might as well fill it with goo as well.
    Getting carried away......
  • Time for fun
    Emerica03/09/2016 at 09:42 0 comments
    Found a cool skull and tried an inlay!, I'm happy.
    Tried some neck pockets for guitars, just experimenting and learning :)
    I didn't have any larger end mills so the video is very long.
  • Threaded Inserts
    Emerica03/09/2016 at 09:36 0 comments
    After watching Winston Moy flood his cnc with threaded inserts I thought that I wanted to do the same, so I worked on creating a job to do inserts.
    Happy with the results I was able to make a trip to home depot and get some materials. With some MDF and threaded inserts I made a board that will overhang the small lip of the Shapeoko frame rails, allowing me the full cutting area as well as many clamping locations.
    I haven't really used it much. But I also haven't made any clamps to use with it.
  • Getting Started
    Emerica03/09/2016 at 09:15 0 comments
    After a long preorder wait I was finally able to get my machine running and drawing the example.
    I had some troubles with sizing. Which required configuration of the microswitches on the carbide motion PCB and some GRBL settings.
    This information is documented in the Shapeoko setup.
    What should the DIP switches be set to on my Shapeoko3 controller board?
    The DIP switches on the board should be set to:
    • N23 rather than N17 (this is the motor selection)
    • 1/4 rather than 1/8 (this is the micro-stepping selection)
    $100=40.000 (x, step/mm
    $101=40.000 (y, step/m)
    $102=40.000 (z, step/mm
    Now it's time to test something a little closer to home. Something I hope to laser cut in the future. Gaskets for engines. Mostly moped engines. In this case Tomos A5x Gaskets. It's something I had tried to do on my vinyl plotter, but had problems with thick materials. (Compared to vinyl)
    Looking good.
    http://pxn.ca/moped/Tomos/cnc.zip
    Updated as I make changes, probably move these to github soon.
    Another project I'd like to tackle is guitars.
    so time to draw a flying V for fun
View all 6 project logs
