Hackaday.io Hackaday.io
Sign up Log in
pin^2: An augmented approach to breakout boards
pin^2 is a more versatile breakout board with space for extra components
analog-twoAnalog Two
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3 comments
13 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 3
View Gallery
518
3
13
9
Team (1)
  • analog-twoAnalog Two
Join this project's team
  • Sample application
  • Tindie store
completed project
hardware
breakout
Related lists
Projects using OSHpark boards
projects using the purple PCBs
Awesome Projects on Tindie
Hackaday.io projects you can buy in the Tindie maker marketplace
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 08/23/2015 and last updated 8 years ago.
Description
Breakout boards you find on Sparkfun or Adafruit can only fit a chip. Usually these chips require decoupling capacitors, pullups resistors or the like. This board allows you to add those extra passives onto the breakout itself, making breadboard deployment a snap. Please see the sample application link for more details.
Project Logs
Collapse
  • 0603 version available next week on Tindie
    Analog Two • 07/21/2017 at 03:44 • 2 comments
    I felt inspired to make an 0603 version using solder pads that are bit bigger to facilitate hand soldering.
    I think 0805 is the most popular in the wide field of surface mount hand soldering but having recently made boards with 0603 components I think it is necessary to stock a board for this smaller size as well.
    I have concluded 0402 is a young/near-sighted person's game but don't let that stop you from taking that challenge!
  • Sample application link
    Analog Two • 04/24/2016 at 21:44 • 0 comments
    I used the pin^2 0805 board to make a standalone PWM module. I documented it on this link here
    https://analog10.com/posts/how_to_use_pin_squared.html
  • SOT23-6 0805 Breakout Board for sale
    Analog Two • 04/08/2016 at 14:02 • 0 comments
    Just posted a breakout board for SOT23-6 devices. The breakout board is SIL in design and accommodates pads to place 0805 components across any pair of terminals on the SOT23 IC. So you can pull up your signals, bypass your VCC and GND, etc all one simple board that easily plugs into your breadboard.
    Check it out on my tindie page:
    https://www.tindie.com/products/analog10/pin2-0805-best-breakout-board-for-sot23-6/
    To determine where to place your components, look at the labeled pads below.
    So to put a component across pins 1 and 3 of your IC, look for the pair of opposing pads labeled PIN1 and PIN3 (on the left side of the image below).
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
toby wrote 07/21/2017 at 00:08 • point
This looks super useful. Don't forget to post an update announcing re-availability on Tindie in July 2017! https://www.tindie.com/products/analog10/pin2-0805-best-breakout-board-for-sot23-6
Analog Two wrote 07/21/2017 at 03:37 • point
Thanks for the kind words toby. At the end of next week both 0805 and 0603 versions will be available.
[deleted]
Analog Two wrote 04/25/2016 at 12:28 • point
Thank you for the comment and pointing out the broken link. Should be fixed now.
I designed a replica of the NodeMCU Development Board, which, 10 of them I got fabricated for just $5.
Project Owner Contributor
DIY - NodeMCU Development Board
hulkHulk
The 2018 Hackaday Prize
A small board for the Attiny85 and pin compatible variants for embedding into projects.
Attiny Micro
mcunerdmcu_nerd
A modular breakout board for 8051 and 8052 MCUs that use the PLCC package.
8051/8052 Breakout Board
daves-dev-labDave's Dev Lab
A pin for pin breakout board for the Edison So you can breadboard prototype
Simple Edison Breakout Board
stephen-edwardsStephen Edwards
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "pin^2: An augmented approach to breakout boards", please tell us the reason.
Send message
Remove Member
