RaspiTrap V1.0
How to catch a mouse with a Raspberry Pi?
RaspiTrap is an animal friendly mousetrap, with photo, video and email function. You may ask, why somebody would build such a mousetrap? Why not?
Easy,
The mouse enters the Trap. Passes the light barrier. Raspberry detects and activates servo motor. Door closes.
Now the Pi takes a Pic and sends it via IM and Mail.
That's it.
trap4.brd
Eagle PCB
brd - 128.15 kB - 05/14/2016 at 18:34
Download
trap4.sch
Eagle Schematic
sch - 752.81 kB - 05/14/2016 at 18:33
Download
  • 1 × Raspberry Pi
  • 1 × Infrared Barrier
  • 1 × Foam PVC
  • 1 × Servo Motor
  • 1 × Wifi Stick
View all 9 project logs
  • 1
    Step 1
  • 2
    Step 2
    C.A.D. Design
    First of all I tried the design in Sketchup 8, which is still free
    I could try a few designs virtually to see if everything fits.
  • 3
    Step 3
    Housing
    To build the housing (350mmx110mm), I used 5mm foamed PVC Sheets.
    So, I could use a cutter as CNC machine :) ?
View all 8 instructions
polytrans2000 wrote 01/16/2018 at 20:21 point
What motor would you suggest for me to use?
noahdavy18 wrote 01/11/2017 at 21:36 point
Where is the source code used in this project please?
