LED Video lighting Using step down & boost up Voltage
I take Mains 240 Volts A.C. 50Hz into the Laptop Power Brick PA3201U-1AC which outputs 15 Volts DC, (i.e. step down), then I use the Boost converter to increase this 15 Volt voltage up to 30 Volts for two high power 30 Volts, 20 Watt LED's and a 30 Volt, 10 Watt flood light LED. Also power a DIY ring LED's light
I had to carefully adjust the boost convector output voltage to :-
a) reduce LED light flicker
b) reduce heat of the boost converter
The 15 Volt supplies directly:-
Ringlight LED's : Rows of 5 straw-hat LEDs connected in parallel. Each one of the 5 LED's are at 3 Volts each=15 Volts from the power brick.
Number of Straw Hat LED's soldered in groups five LED, 5 LED's x 3 Volts each powered directly off the computer power supply of 15 Volts. These groups of five LED's connected in parallel, to create more light, and hot glued to cut out cardboard as a ring light.
I sanded the tops of the Straw Hat Led's a bit to defuse the light a bit as well.
Dailymotion Video
http://www.dailymotion.com/video/x34jaoo
Related videos:-
LED Videolighting Using step down & boost up Voltage. Some improvements have been made as shown
above
http://www.dailymotion.com/video/x34jaoo_led-video-lighting-using-step-down-boost-up-voltage_tech
DIY Adjustable Camcorder Light Stand. Some improvements have been made as shown
above
http://dai.ly/xmnvd2
eBay 100W LED
Collimator and reflector, unboxing review. (Not uses but interning)
http://dai.ly/x2dwnq9
LED wiring andreview 20 Watt AC Mains DC Driver DIYhttp://dai.ly/x2dxd8leBay 100W LED Collimator and reflector, unboxing review. (Not uses but interning) http://dai.ly/x2dwnq9 LED wiring and review 20 Watt AC Mains DC Driver DIY
Films4You
Luke Skaff
Michael
MagicWolfi
Est
