VFD clock using opto-copplers as drivers and an arduino as the multiplexing controller
I see that I made a mistake; it should be MAX6921. good luck :)
Very cool project, do you happen to have more info such as schematics and code?
Maxim also has a chip that can replace the optoisolators the MAX6922
I have to say, that I can't really recommend building this clock as such.. MAX6922 could be a good thing, but I couldn't get the VFD grids to switch fast enough to eliminate all ghosting.
I need to take a look at the 6922..
Ian Jordan
Marcel Ochsendorf
engineer2you
thehighestfever
Yes, delete it Cancel
You are about to report the project "VFD clock with ESP8266 NTP sync", please tell us the reason.
