1Step 1
This is instructions for building just the ICSP version of the backpack. Adding the FTDI section is very similar.
2Step 2
Cut a perf board down to at least 6x13. You want it 2 holes wider than the atmega footprint, so the male breakaway header "legs" will straddle the chip.
3Step 3
Figure out how you're going to wire up your 2x3 header block to the legs. Basically just connect everything together. MISO to MISO, VCC to VCC, etc.
4Step 4
Before you solder anything, a note on the legs: Add a couple extra legs for alignment, stress relief and stability. At least fill the first 2 holes on both sides (atmega 1 & 2, 27 & 28).
5Step 5
Solder everything together.
6Step 6
Try it out!
Jeremy
