align_display2.gcodeGcode for the allingment perforationsgcode - 309.00 bytes - 03/01/2017 at 00:07 |
bottom_display2.gcodeGcode for the bottom face of the 7 segments displays PCBgcode - 141.14 kB - 03/01/2017 at 00:07 |
drill_display2.gcodeGcode for the drills of the 7 segments displays PCBgcode - 2.66 kB - 03/01/2017 at 00:07 |
Top_display2.gcodeGcode for the top face of the 7 segments displays PCBgcode - 145.86 kB - 03/01/2017 at 00:07 |
max_top.gcodeGcode for the top face of the max7219 PCBgcode - 154.51 kB - 02/28/2017 at 23:52 |
max_drill.gcodeGcode for drills of the max7219 PCBgcode - 4.29 kB - 02/28/2017 at 23:52 |
max_bottom.gcodeGcode for the bottom face of the max7219 PCBgcode - 154.42 kB - 02/28/2017 at 23:52 |
max_allign.gcodeGcode for allingment perforations in both facesgcode - 332.00 bytes - 02/28/2017 at 23:52 |
schematic.pdfA wiring diagramAdobe Portable Document Format - 533.32 kB - 02/28/2017 at 23:50 |
Sin título.jpgA shield for arduino. You should make a shield or wiring in a prototyping shield.JPEG Image - 94.25 kB - 02/23/2017 at 16:57 |
midilooper.inoThis is the arduino's sketch.ino - 9.36 kB - 02/23/2017 at 16:30 |
