1-Cell MCU
Run a low-power MCU efficiently from an AA(A) or button cell
Microchip markets the MCP1624 boost converter as a solution for powering PIC MCUs in single-cell applications. The downside of this part is the 60uA or more quiescent current (measured at Vin). By using a GPIO line to strategically shut down the converter, the quiescent current can be reduced dramatically, allowing for efficient MCU sleep and longer battery life.
This project is really all about a resistor.  Specifically, the 1.5M resistor, R3, in the schematic below.
The MCP1624 is a DC-DC converter that will start at voltages as low as 0.65V (typ), so is ideal for running a PIC or other MCU from a single AA(A) cell or similar 1.5V nominal source (even button cells).  But, it's not exactly nano-power.  The graphs in the datasheet show a 100uA quiescent input current drain for a 1.1V source and 3.3V output, and it gets worse as the battery voltage falls.  The goal of this project is to bring this current down.
The idea is that the PIC can shut down the converter during sleep or periodically when running to minimize the current consumption.  I'll admit, having the PIC shut off its own power supply sounds like a recipe for disaster.
That's where R3 comes in.
When power is first applied, the PIC GPIOs are tri-stated, so R3 turns on the MCP1624 by pulling the enable input high.  The MCP1624 comes on and charges C1, a 70mF supercapacitor, to 3.0V (selected with R1 and R2).  When the PIC needs to sleep for a while, it can disable the MCP1624 by setting RA2 to an output and pulling it low.  At this point, the PIC is running from the energy stored in the supercapacitor.  This particular PIC has a low-power brownout reset (LPBOR), which will monitor the supply voltage and reset the PIC when the supply drops to a predetermined level.  Should the PIC not wake up in time to re-enable the supply, the LPBOR will reset the PIC, which returns the GPIO pins to tri-state, starting the DC-DC converter again.
I expect that the normal mode of operation will be to set the sleep time so that this never happens, and the capacitor gets fully recharged periodically without the PIC resetting.  But, the safety net is there just in case.
I'm grossly violating the 100uF maximum output capacitance spec for the MCP1624 with C1.  I am hoping to get away with it due to the large ESR (100+ Ohms) of the selected supercapacitor.  This 100-ohm ESR doesn't matter when the PIC is in sleep, consuming a few uA maximum, but hopefully is enough to keep the MC1624 stable.  Now that I think of it, I should have added a site for an additional series resistor for C1 in case it's needed.
The leakage current for the supercapacitor also isn't specified.  This could easily dominate the current drain.  Plan B is to find some other large-ish, low-leakage capacitor(s).
I don't know yet exactly how low the sleep current will be, but I'm shooting for less than 5 uA.
I have some test PCBs ordered from OSH Park, and now just have to wait :(
The initial design is in the githubs, but not tested yet.
  • Better part, but very small
    Ted Yapo6 days ago 0 comments
    So, I found the TPS61099x series of boost converters, which claim 1uA quiescent current and 75% efficiency at 10uA load.  These look usable out-of-the-box for micropower 1-cell MCU applications.  I do wonder, though, if the same shutdown trick can be used to reduce the sleep current even more by running the converter at higher current (and higher efficiency) to periodically charge some low-leakage storage caps.  I'm going to order a few and test them out.
    The downside I can see to this part is that the only package option stocked at DigiKey is a 1.23 x 0.88 mm BGA.  That's pretty small to assemble at home.
    Another small PCB from OSH Park coming up.  At least I'm batching them now, so they don't have to send me an envelope for $1 worth of boards :-)
View project log
