Schlieren-Videography
Back to overview
With this project I want to show you how you can make Schlieren-Videography at home. To do so we will use the Moiré-effect.
pyroartist wrote 01/12/2016 at 03:58 point
I unzipped the file labeled "Moire.7z New" but I don't find any code in there. Is this for a PC program or for something else? It does not say in the instructions. And what is that  Moire.PDE file for?
Jana Marie wrote 01/12/2016 at 16:23 point
Hi, you need to load the .pde file into Processing (https://processing.org/) and then press the "Run" button.
