DRONI SAME70Pi / 1.ELECTRONICS / PCB-TOP POWER USE
A project log for Open Source All-In Drone-Droni SAME70Pi (Kopernik)
Yet another open source platform for drones, but this one is fully integrated and uses the SAME70@300Mhz x2 + a Pi Compute Module
laetitia-belLaetitia BEL 03/20/2018 at 23:500 Comments
Here is the interfaces regarding the power needs/uses and the front sens connector.
It describes the connector used in the TOP PCB.
There are mainly three types of connectors:
- JST/Molex 1.25mm like 6p
- JST/Molex 1.25 like 3p
- PFC connectors for the RPI CAM sockets and for the front sens panel
The power of the RPi CAMs are not represented, they are directly distributed by the compute module.
The SAME70-M1/M2 are powered with the same converter.
Each signal connector (UART, DAC,..etc) has GND/3V3/Signals, the 3V3 comes from a dedicated converter.
The communication modules are also powered by a dedicated converter.
